Question about Wahl 8685 Hair Trimmer
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
RESISTOR BURNED OUT CAN'T READ BANDS WHAT IS THE OHMS
  • Iwiltry Mar 04, 2009
    i have the exact problem. the resistor is blown there is no way of reading the color code. what is the resistance of this resistor?
  • raskacielo Apr 16, 2009
    same here!!!
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Posted on May 14, 2009
Value of R065 on power supply module of the RX-884V
value not cost $ but a resistor is it to hard to say resistor.?
OHMS and color bands all that is easy but no VALUE eve guessed
and if burned up and my guess it did (not said)
and guess what even if you had a correct resistor
it too will burn up, due to other part is shorted 99% chance.
see?
HP does not publish schematics.
what we do is buy a new one. every time.
Feb 21, 2016 | Compaq rx884-69001 - 2.4x Ide Hd Dvd-rom...
How i can recognize the value the 2 resistors that were burned.
Measure The Resistance Of Each Resistor With A Digital Ohm Meter, If They Still Read Value, The Original Value Is Much Much Less..What Circuit Did TheyCome From ?
Sep 10, 2014 | Televison & Video
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Does anyone know what value the R99 resistor is on the true sub junior
R99 on the Sunfire True Sub Junior is a surface mount resistor (no color bands), and measures 51k ohms. R102 near it is colored gray, red, brown, gold.
Jun 16, 2012 | Sunfire True Sub Jr Subwoofer
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
I have a FISHER Model RS-914A and I don't know what's the value of R211 and R212 . I removed these resistors and they measured 222 ohms. But I don't know if the value is 220 ohm. please help me with this...
Are they burnt up so you can't read the colour codes?
220 ohm even marked up as that could give a reading of 222 or higher (or lower) and work fine. Remember the gold or silver band gives a 5 to 10% varation in value.
May 31, 2010 | Audio Players & Recorders
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
WILL NOT TURN ON
Sir;
friend of mind had the same model # and he give me the color band for the resistor
Nov 18, 2008 | Yamaha HTR-5560 Receiver
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
Wahl Peanut model 8685
yes they make current adaptors for everything these days but you will need to change the regional code to work properly
May 10, 2008 | Wahl 8685 Hair Trimmer
Wahl 8685 Hair Trimmer Logo
616 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
