Question about GE Refrigerators
TMQ12ANTRLG GE Refrigerator-freezer model TMQ12ANTRLG the freezer unit not working
  • 114 Answers
SOURCE: ge refrigerator model TFH22JW problem
You most likely have an automatic defrost problem. When one of more of the defrost components fails, frost accumulates behind the freezer wall and restricts airflow to the fresh food side. You will still generate cold into the freezer section but will have virtually no cold to fresh food side. If it is a few years old it is most likely the defrost heater which is defective. Replace the defrost thermostat (bi-metal) as well.
Posted on Oct 02, 2007
  • 833 Answers
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Posted on Dec 12, 2008
Milleniumboy
  • 106 Answers
SOURCE: Refrigerator and freezer stopped making cold over night, its a GE
Try to check for Warranty protection, and if the time coverage has not yet elapsed. If it has not, try to take to service technician, if it has, then the problem is just the Coolant, a chemical liquid that when its volume is expanded, its temperature drastically drops, its called freon. Try see if you can replace the coolant. :)
Posted on Apr 26, 2009
  • 103 Answers
SOURCE: freezer works refrigerator doesn't ge tbx-25zle
Hi: Your defrost heater or defrost timer is bad. There is an off chance your freezer or fresh food compartment are so full they block the airflow. If not full, Remove the food from the freezer, unplug the ref. and hit the back wall of the freezer with a hair dryer. Avoid plastic components as they will melt. When your defrost mechanism fails frost will form where it shouldnt and block the airway to the fresh food compartment. That's why the freezer still works. That will get you a week or two of fresh food getting cold. If your'e handy remove the back panel of the freezer at the bottom will be a glass tube with a metal coil in it. If the coil is broken buy the new defrost heater and install it. If not look for a defrost timer. Use the model number of the refrigerator to find the part. www.searspartsdirect.com will have a parts schematic to help you find out where the timer is located. There shipping is high so try to buy it locally. I hopes this helps, Jeff
Posted on Jun 25, 2009
mgprice
  • 744 Answers
SOURCE: Freezer is working but the refrigerator is not.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Posted on Jul 10, 2009
My unit is not cold enough refigerator or freezer. GE Model #: PS 123MGTA - Serial#: GL406451. I continue to push the adjust temp button to no avail. The freezer is set to 17 and the refigerator is set...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | GE Refrigerators
My GE TBX22Z runs about 22 hr/day. I have coolness controls set in middle. Freezer is 15 below and fridge is 38-39 degrees. The unit is 23 years old. Should I get a new model?
heatman101
May 21, 2011 | GE GTS22KBP Top Freezer Refrigerator
MY GE Refrigerator-Freezer , model TCX20 motor is humming!!!
There may be a build up of ice in the freezer compartment and ice touching the fanblade. The unit needs to be defrosted.
Nov 06, 2009 | Samsung RS2630WW Side by Side Refrigerator
Ge model GSS201ETA NOT COOLING AT ALL
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
dsfhfs
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
