Installation of akm 47080 - Computers & Internet
What was year of manufacture of Browning .22 lr semi-auto rifle serial number T80 1286?
Hi the number you list doesn't seem to be right "T" designates a 22L/R the 80 seems to be in the wrong place if the 8 was in front of the letter T it would be a 1968 rifle, the system changed in 1969 to 1973 and again in 1974 when production was moved to Miroku in Japan
Apr 26, 2014 | HOT TOYS 16 Modern Firearms 3 Akm W Drum
I need to know if safety 1st Saunter Travel System "Picnic Trees" Model # TR 202 AKM, UPC#88439256694 is still considered safe and why that model is not being made anymore.
Hi Glenda
Can you please advise which country you're in so that we can put you in touch with the customer care team in your country / best equipped to help with your enquiry.
Oct 23, 2013 | Safety 1st Baby Gear
I forgot my security code nokia 5130c-2 no.354179039374743
Either goto customer care or u should try a software namely jaf..
Like this post and email me at akm.2515@gmail.com, i'll tell u how to use jaf
Apr 15, 2011 | Computers & Internet
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
I have Belguim Browning sweet 16 with a serial number 2s95067 was wondering what year it was made
Go Here:
http://www.browning.com/customerservice/dategun/index.asp
for the answer to your question. The auto 5 had several number schemes during its production. Make sure you are reading the serial # correctly.
May 31, 2010 | HOT TOYS 16 Modern Firearms 3 Akm W Drum
No visual
This is a common fault with the 360, it says that its a "general hardware failure" which could mean anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but graphics or sound and no graphics just like you are reporting.
Firstly get a spare av cable from someone else, try this, if that does the same then try a different scart
input on the tv. if all this fails you need to fix your machine as it WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet. Im in the middle of producing one right now that i will make available free of charge for all fixya
members.
Linda
www.xboxrepairkit.co.uk
Sep 26, 2009 | Microsoft Xbox 360 Console
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
