I have installed and reinstalled all big fish games they just flicker and go off. They worked fine in windows 7 . but now that I have upgraded to windows 8 they flicker and nothing.
SOURCE: Mouse cursor flickers and dissapears on Football Manager 2009
Hi, have you check the mouse setting in the control panel?
I think your mouse has a problem if you can verify that the setting is normal.
I would suggest you try with different mouse to narrow down the problem.
Hope this help.
Kam
SOURCE: HP mini 1000 webcam wont work windows 7
please refer to his link for your drivers http://tinyurl.com/y9fbwzh
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: VAIO VGN-NS240E/W PC Notebook: I upgraded from Vista 32 bit to Windows 7 32 bit (...
It is required to install the following Drivers/Utilities in the following order to fix the issue with the functions Keys.
You can click on the link to download the Drivers/Utilities.
Video Driver.
Video Driver Update
Audio Driver.
Sony Shared Library
Sony Firmware Extension Parser Driver.
Sony Firmware Extension Parser Driver Update 1
Sony Firmware Extension Parser Driver Update 2
VAIO Event Service.
Please download each file in the Computer to a folder. After that open the folder where the file was downloaded and double click to begin the installation. Then, please follow the onscreen instructions to complete the intallation process. Make sure that you restart the Computer after each installation. Installing all the above Driver/Utility in the correct order should fix the issue with the Volume/Brightness Function Keys.
Good luck...!!
SOURCE: my cd rom is not
Simply install nero again by running the software again. It will say that this installation will overwrite the previous installation, say yes & proceed.
