Hooking-up a new monitor to my laptop
I would like the new 20" monitor to replace the laptop monitor. How do I move the display from the laptop monitor to the new monitor. ?
  • 124 Answers
Find the connector on your laptop that matches your new laptop. Plug it in and let Windows discover it....
It probably will say something like "found new hardware" and will install a "generic" driver for your new monitor. After the driver is installed (and Windows should tell you that the device is ready to use", Find the row of keys known as function keys. Usually, all function keys on the top row have a second set of symbols on the "f1 through f12 keys. You should see one the looks like "lcd" which refers to the monitor on your laptop and the other that shows a rectangular symbol with an arrow indicating out to an external monitor. Once you hold the function key down and press whatever key shows the symbol, the laptop image will switch to the new monitor. To switch back to the laptop screen, reverse the process. Thanks for using Fixya.com.
Posted on Jan 27, 2009
No display it is power is on
Hook up to external monitor .. Does the pre boot screen pop up (black and white writing at start ) ? If display runs on external monitor then your screen needs replacing usually or if you see a vague image on laptop screen then inverter or backlight is gone .. if no display on external and no pre boot screen probably the graphics chip on laptop has malfunctioned.
Dec 15, 2014 | Acer AL2021M (Silver) 20" LCD Monitor
How do I fix the color?
No! the problem is in the LCD panel display, behind the LCD is a large circuit board that process video, colour, brightness, and balance, if that goes wrong it throws the colour content off, replacing monitor best option. But first it would be a good idea to sub the video cable from the monitor to the computer to cover everything and hook a spare monitor to the computer to rule out the video graphics card.
Apr 30, 2012 | SVA-USA VR-20 20" Flat Panel LCD Monitor
Montor blinks white
If this monitor is new return it to the place of purchase, the problem is in the LCD panel display, if out of warranty! cheaper to replace.
Mar 24, 2012 | E-Machines E202 20 inch LCD Monitor
I have a Toshiba Latop (P105 S6217) (SN=17122387W) (Mod=PSPADU 00W00S). In recent days, I am getting very thin lines across my display screen. Could this possibly been the Mother Board going bad. The...
You possibly have a LCD screen failing, but to be 100% sure, you should hook your laptop to an external monitor, and see if the display is good . Any desktop monitor will work. If your display is good, you know your LCD on your laptop is failing, and if it is the same display as your laptop, you know you have a video chip problem on your laptop motherboard.
Sep 21, 2010 | Toshiba Computers & Internet
I got a new power coed and now the screen on my laptop is green and fuzzy
check if its the monitor/lcd or the videocard is the one having problems, try to hook a known good external monitor. if it has the same bad display, its the videocard. if it has good display, then the lcd/monitor is the part you need to replace. also try different adaptor and see if problem persists.
Mar 29, 2010 | Compaq Presario 700 470024-192 Notebook
Apple cinema display has interference
Check your DVI cable for breaks. If that's not the problem, then you'll need a new IP board. Not sure of the part number for this monitor, it's printed on the circuit board. It starts with 820-XXXX or 620-XXXX in some cases.
Nov 24, 2009 | Apple Cinema 20" LCD Monitor
Tried hooking the computer to an external monitor. Got the welcome screen ok, then it lost sync and went black. Tried it on another plasma; same result. SVGA cable connection.
Hi there. When you connect an external display, your laptop clones your desktop to the external display, including resolution settings. First you need to check what resolution settings the plasma can display. If your laptop is set to a resolution that the external monitor can't display, then you will lose the display once the resolution settings are loaded. You can change the laptop resolution in your Display Settings.
If you don't know what settings the external monitor can display, just open your Display Settings and set your laptop resolution to 1024x768. Almost all new monitor/tv's can display it. Connect your external display, and see what happens. If it works, but the resolution doesn't look right, then just move the resolution along one more, until you find one you're comfortable with.
N.B. Some monitors/tv's "jump" resolutions. i.e. the monitor can display 1024x768, 1300x768, but not 1280x800.
Another thing to remember is that if you are running Windows Vista, you may need to check that the Windows Mobility Center recognises the external display that you are trying to use. You can find Windows Mobility Center by clicking Control Panel, then Mobile PC. It should now be listed on the screen.
Let me know how it goes, and if it works, please rate.
Tim
Apr 17, 2009 | HP Presario V2401cl Notebook
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Display problem
If you have no power you may replace the power supply. The power supply is part of the power cord. If you have power and no display, are you able to hook the laptop to a monitor? That would allow you to atleast access the machine. Let me know what happens. Tim
Mar 21, 2007 | VIA Balance 14.1'' Laptop, 1.0 GHz C3...
Computers & Internet Logo
510 people viewed this question
David Payne
David Payne
