Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
How do I connect a Nintendo 64 games system to a Hitachi TV?
I just got a Nintendo 64 off of eBay & I can't wait to play it.....but I can't figure out how to get it connected. I only have a DVD player hooked up to my TV, so I am not sure where the game should go. Can you help? Please be as clear as possible - I am not very mechanically inclined :(
  • kdg1026 Jan 27, 2009
    There are only two cords off the game itself - the one that plugs into the wall (electrical outlet) and the other one is a round cord, has a small black box near the end that has a cord with a silver 'cuff' that has a very thin straight piece to plug into something...the black box says "RFU Adapter for Gamecube". The little silver piece comes out of that on that box there is a part that you can screw something onto that says Antenna. At the bottom of that same box it saya A/V In, & beside that it has a little switch that says Ch Select 4 3......
It would seem that you did not receive the AV (Audio/Video) cables (Red/White/Yellow) but an RF adapter instead.
You have a couple options.
1) connect the RF adapter to an "Antenna In" if there is one on the back of the TV, then select channel 3 or 4 on the remote and the adapter or...
better option
2) purchase the AV cables either new or used from a store (gamestop, etc) You may still find new cables for the Nintendo Gamecube (3 Nintendo systems used the same AV cable) or used ones listed as being for the Gamecube or N64.
It's the better option because these cables offer better audio and video quality
Cheers
Posted on Jan 27, 2009
  • 362 Answers
Hi kdg 1026,
The wire from the Nintendo should have 3 plugs on the end. Yellow, Whit and Red.
OPn the baqck of the TV you have inputs that are color coded, Yellow, White and Red.
Plug the wires into the color coded inputs.
Turn on Nintendo. Press input button on your TV remote until you get the picture.
Let me know if this helps.
Please rate this solution. Lone99star
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
Vcr/dvd player and nintendo 64
you N64 should have the cable with yellow/red/white connections(RCA) Those should plug into the VCR ports that say Input. Then run that to your TV through the screw on Coax cable.
Nov 25, 2013 | Nintendo 64 Console
How to connect nintendo 64 on a dish network tv
Can I connect my Nintendo to my Cable Box, my DVD, or my VCP (video cassette player)?
Your Nintendo system requires AV inputs to work. These products do not provide inputs. Connecting to them is not possible. Unless you get a blue plug for it to work then with the connection then.
Aug 01, 2012 | Nintendo 64 Console
How can I hook up a nintendo wii through my
Hi, There should be an av button.
do you not have spare connections on your tv?
This is your best way, unless you want to record what you are playing.
Which model do you have?
I will try and help
Regards - Anthony
Feb 08, 2010 | Philips Magnavox DVD/VCR Dual Player
Just got a n64 off ebay power cable and an antenna cable came with it. no idea how to tune the tv so i can play it!!!!!! i have tried manually and automatically searching through all the components and...
It has been a long time since I have used one but I believe you can hook it directly to the rca jacks in the back of the tv... then I believe you need to be tuned into the AUX chanel on your tv set ... some tv's if you hit 00 this puts you to it ..others start from chanel two and go down ... hope it helps .. have fun playing the 64
Oct 16, 2009 | Nintendo 64 Console
I cant figure out how to run it through my dvd player
You should not be able to, the Wii has a mini disc player and is not compatible with any DVD player. The DVD player should have two plugs on it, one to the wall input and one with yellow and red input jacks if you don't have a AV in-put out-put connection on your TV then you need a adapter for to TV for the DVD player.
May 19, 2009 | Nintendo Wii Console
Trying to hook up having problems with connication ,need manual
Okay... with limited information I'll give it a shot...
Depending on the age of your tv, sometimes they have multiple input options. Since you are referring to hooking it up with cable, I'm guessing that you are using a coaxle for your super nintendo. The easiest way to get it hooked up it to upgrade to a 3-prong AV cable. You can find them on ebay for about $2.
If you don't have any open inputs on your tv you will need to either continuously change what is connected to the tv (unlikely) or buy an RF switch from any store that sells electronics. I think they are running $20 or less now adays. (They are worth the cost because they allow you to connect DVD player, VCR, game component, etc all using one input on TV.)
Mar 13, 2009 | Nintendo Super NES Console
I can't figure out how to hook up a wii to a home theater system
On the back of your AVR (audio video receiver) where you connect a DVD, VCR or any other component. Example if there are open component jacks where you would connect a VCR just plug in the Yellow, Red and White cables. Turn your AVR to the source you connected to and turn on the TV. It should then play thru the speakers and be seen on the TV. Treat it just like a DVD player or any input source.
Dec 31, 2008 | Nintendo Wii Console
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
2,093 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
