Question about Briel Breil Bw0429 Milano Chrono Watch for Women
Battery replacement for my briel watch - Briel Breil Bw0429 Milano Chrono Watch for Women
How can you get an instruction manual for this Breil Milano BW 0493 watch?
Manufacturers don't usually reinvent the wheel. You may be able to find something from one of these: http://fitness.manualsonline.com/manuals/mfg/briel/briel_watch_product_list.html
Jun 18, 2014 | Breil Milano Bw0493 Milano Chrono Lady...
Tip
Finding replacement battery for watch (DIY).
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
on Jan 20, 2010 | Watches
How do i reset the big hand to zero. it is the chronograph
pull crown out to second position then press start button till it gets to zero then push crown back in
Sep 15, 2013 | Briel Breil Mediterraneo Time watch...
Need to purchase a replacement rubber strap for my Breil watch. The strap # is BW0379. Where may I purchase one?
visit http://www.kkhservices.co.uk/ All Breil straps are very expensive ive just found out as i need to replace my rubber strap and was quoted £57 and £150 for a metal bracelet!!!!!
Aug 31, 2011 | Briel Breil Bw0379 Mediterraneo Chrono...
The long second/split time hand resets to 58secs and not 00secs
You have to set the long second by pulling the crown to it's third position(which you can set the time) then push the upper button until you reach 00 then push again to normal position. that's it. i hope i had helped you...
Jul 10, 2011 | Briel Breil Milano Chronograph BW0491...
Briel two241 brand new from Amazon - wont start?
hopfully its just a battery, they only last 2 yrs, swiss is 3-4 yrs.if battery dont work , could be circuit or mechinec's of watch, repalce movement .. if new send them back. battery changes may be remeburst
Jun 17, 2011 | Briel Watches
I need to fix the date on my breil tw0287. how can i do this?
mcdevit75 here, If your watch has a stem (winder) simply place your fingernail under the stem and gently lift the stem to it"s first notch (position) now you should be able to turn the stem (winder) to change the date push the stem back in when date is set.
Jun 23, 2010 | Briel Breil Globe BW0213 Watch for Men
Battery replacement
If you have a warrantee with your watch you may have to return thew watch to the manufacturerer for battery replacement. Othet than that, most any jeweler can replace the battery. Mike D 75
Jun 07, 2010 | Philip Stein Teslar Stainless Steel Small...
Battery Replacement
I thought you are supposed to touch the neg side of the battery
Jun 01, 2008 | Casio DBC1501 Wrist Watch
Briel Breil Bw0429 Milano Chrono Watch for Women Logo
23 people viewed this question
Top Briel Watches Experts
Jimmy Accardi
Are you a Briel Watch Expert? Answer questions, earn points and help others
