Question about Pantech Renue - Black Cell Phone
Disable sos button
How do you disable the sos button
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Tip
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
with IC8001 (Pesks Lite 2)
on Apr 12, 2009 | Panasonic Viera TH-50PX80U Plasma TV
Tip
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
becomes
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
Hi I have a TH50PZ80U that is flashing two red lights when I plug it in. If i press the power button for 5 seconeds it will flash 10 times. When applying power the AC relays click, after pressing the...
Hi bschaub796,
10 times blinking of your unit indicated that the processor sense the missing 15v from the power supply. This problem is quite technical since I've already read your post that you have a reading of 15v in P25.
Now, we have to examined it deeply to determine where the fault came from between the two board.
If you have a 15v coming from the power supply but its go to 0v after a while which trigger the 10 blinks, you have to check the feedback circuitry of the power supply for faults. If you can't find any faulty parts on that section means that the feedback circuitry trigger to shutdown because it sense fault in the D board.
Remember that it has a good regulation output from the power supply, the issue here is the feedback circuitry that sense the fault. If you are going to ask my opinion I've suspected that the fault is in the D board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 17, 2011 | Televison & Video
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Sos button
What model year of Porsche do you have, and which model? I've never seen one anywhere in any Porsche vehicles I've been in. Here's what I think happens:
1. You press the SOS button in the Porsche.
2. The audio system mutes.
3. In 3-5 minutes, if you have subscribed, the operator connects.
4. You press it again to disconnect.
It is an emergency button.
Jul 12, 2008 | 2005 Porsche Carrera Gt
SOS call was activated. How Deactivate it? 2
Push the "R" button (last button on the left side) two times.
The the "sos" should be deleted.
I also uploaded the manual (only in french). The solution ist on page 10.
Mar 23, 2008 | Alcatel One Touch FIRST 20 Cordless Phone
Pantech Renue - Black Cell Phone Logo
417 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
