Question about John Deere 22HP Hydrostatic 42" Riding Mower
Where is the service light indicator on dash of john deere x595
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: I have a X595 John
It might be on the inside rail of your steering sector.remove left side air screen,look at colum brace/frame that holds your dash and reach to the inside of frame for the regulator.This is where they would be on the gas models.
Posted on Sep 07, 2010
  • 102366 Answers
SOURCE: jugn deere 6400 manuel
You can download the appropriate manual from the manufacturer's web site at
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&tM=FR&searchCriteria=6400&language=english&submit=Search
Posted on May 19, 2011
kel1guy2002
  • 3740 Answers
SOURCE: need to reset my oil service light on my john
Hi and welcome to FixYa. I am Kelly.
The light (blinking notification on digital read out) will come on 1/2 hour before and remain on for 1/2 hour after the interval. If you pass your model number I can paste the notification data. It is NOT re-setable.
How Does Your Hour Meter Function? Model Year
Model Number and Product Identification Number Groups. Is the tractor equipped with an hour meter? Does it accumulate hours with the key switch left "ON", but not running? How long does the service reminder (SVC) display before and after service intervals? Does the Hour meter stay lit or display hours when the key is in the" OFF" position? Does the hour meter only count hours when the engine is running?
2008 - 2011 D100 D110 D120 D130 D140 D150 D160 D170 LA105 LA115 LA125 LA135 LA145 LA155 LA165 LA175 Yes No half hour No Yes
^- This was a chart... It did not pst well at all. The key is that the interval underlined above is 1/2 hour before and after the service due period and it is NOT resetable.
Thanks for choosing FixYa,
Kelly
Posted on Jul 19, 2011
  • 100 Answers
SOURCE: Do you know if I can put a motor off of a John Deere GX 85 onto my John Deere Sabre
as long as the lenth and diamather of the crank shaft are the same
Posted on Oct 26, 2012
John deer X595 dies when I let break out ran good parked it went back now push brake start let out dies
Sounds like the brake safety switch has gone bad. Take it off and test it.
Dec 21, 2015 | Garden
Fuel gauge not working
Sounds like the fuel sender is stuck or fuel sender selector has bad continuity or the contact on it is worn.
Oct 14, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
The service engine light came on at 8 hours. i changed the oil and filter etc. How do I get the service light to stop blinking that it needs service?
The service engine indicator will stop blinking on it's own. It is just a friendly reminder to have your machine serviced and cannot be reset. It will subsequently come on every 25 hours and last approximately 1 hour. That is if it's a John Deere mower. Hope this is what you're needing, Daniel.
Sep 03, 2011 | John Deere 22HP Hydrostatic 42" Riding...
I have a JD X595 Diesel. This is what happens, say if I start it, then shut it down it will not start again right away. The first time it starts the glow plug light comes on. Shut it down and try to start...
Before you do anything grab a test light, remove the wire from your glow plug, put one end of test light on positive on your battery and the other end on the glow plug, if the light comes on than your glow plug is ok, if not replace, otherwise you need to locate the relay/sensor that tells the glow plug when to go off/on which is more than likely the problem, you may be able to locate it by tracking the wire from the glow plug or your local John Deere service provider may be able to tell you exactly where it is over the phone.
Jun 09, 2011 | John Deere 26HP Hydrostatic 54" Riding...
I have a X595 John Deere Lawn Tractor. My voltage runs up to 21 volts and has burned out the lights and fried the ignition switch and harness with relays. I replaced the ignition harness and switch but...
Sep 04, 2010 | John Deere Garden
John Deere 22HP Hydrostatic 42" Riding Mower Logo
193 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
