Question about LG Televison & Video
What does it mean when the DVD player says "Wired Dynamic IP is not set"?
5 Suggested Answers
  • 147 Answers
SOURCE: problems with netgear wireless router
picolas and nannysboy,
You can setup your router any way you like after accessing it. You don't need software for NetGear. All you have to do to access the control panel is:
  1. Open your browser.
  2. Type in this ip address - http://192.168.1.1
  3. Configure the router as you see fit. It's fairly simple and has built in help guides.
If you cannot connect by wireless, do the above while connected by a LAN cable (looks like a telephone cable, only fatter and wider).
The router should be connected as follows:
  1. WAN port directly to cable/dsl modem.
  2. Any port (1-4) running out to your computer.
Please let me know if this helps. Good luck!
Posted on Mar 01, 2008
SOURCE: Dynamic IP address
There are two kinds of IP addresses: Dynamic and Static. A dynamic IP address changes (refreshes)from time to time while a static IP address remains constant. Dynamic IP is in most cases considerably cheaper than a static IP which for single users probably isn't worth the extra expense.
Posted on Jan 11, 2009
megax01
  • 50 Answers
SOURCE: IP settings
Yes it is but you'll have to get the Dynamic IP from a DHCP server or a router capable of doing DHCP. If you have one of these then all you need to do is:
Control Panel
Network Connections
Double Click on the network link your using
Properties
Under the Connection uses the Following Box Click
TCP/IP
Properties
Obtain an IP Address automatically
OK
and your done. This is for XP but Vistas pretty much the same with some slight differences
Like I said before though u'll need a DHCP source external to your PC to give you an address
Posted on Apr 29, 2009
  • 1768 Answers
SOURCE: No Internet access. Wep personal Connects to
1. You possibly may have the IP address statically assigned in the NIC card properties and or the router. ???
2. Go to the control panel then to network then check the properties of the TCP/IP procol properties to see if you have it set to "obtain an ip automatically"
also see if you have " DNS to obtain automaticall".
3.Unplug the ethernet cord for about 30 seconds the connect it back to the ethernet port.
4. check to see if you have a connection to the internect.
5. call your ISP to see if you line has had any disconnects or maintenance.
6. check the router status ( this will tell you if you have disconnected from the ISP 's server and need a possible reset .
7. Do a ipconfig /all to see if you have the "media disconnect" error > this is done by going to the command prompt and typing "cmd" enter then you DOS prompt will show.
8. check you status lights on the router to give this information to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
I hope this helps. Have a great day!ormation to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
Posted on Aug 22, 2010
Hello all, I've been having trouble connecting LG BD670 (smart blu-ray player) wirelessly to my new wireless gateway. It used to work with my d-link router after changing a few settings that I don't...
Your internet service provider will be able to help you set your modem and router properly to share your internet. In my case, my internet is a ppoe which requires a user name and password. I set my modem to bridged mode, set my router for ppoe with user and pass entered then set up the wireless. Hope this helps.
Oct 05, 2013 | LG BD670 Bluray 3D Player
I have a Vizio VBR120 Blu-ray player and it won't connect to my internet using my NETGEAR WNR2000v3 Router. I have tried using an ethernet cable from router to the blu-ray player. I will not find an IP...
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Mar 05, 2011 | Vizio VBR210 Blu-Ray Player
My asus wl-500gP v2 can't connect to the wan properly... I get the message "you have set the wrong dynamic or stic IP address for you WL-500gP V2." I'm confused because I have it set to dynamic which...
Your ISP address is dynamic, which means every time you log on to your ISP, your WAN IP address changes, this helps to stop hacking. Your ISP even though it is cable uses PPPoE/PPPoA, so you should set your router to this, not dymamic, setting your router to dynamic will make your router look for a different IP address every time your computer tries to log to it, your computer should have e.g 192.168.1.2, which is static, you can check this by going to command prompt and typing ipconfig, see what it brings up. hope this helps and post back if you need further help.
Apr 03, 2010 | ASUS WL-500gP V2 Router
THE BDP-S360 WILL NOT CONNECT TO MY NETWORK. I have tried to manually set up the ip address, etc. I have also tried to let the dvd player do it automatically and it will not recognize any of the settings.
what kind of connection do you have with your ISP provider...
static or dynamic / what kind of connection wired or wireless ?
what kind of router are you using? read your operating manual and call your ISP provider .... they can help you ... bdps300 of sony is like a computer
Jan 06, 2010 | Sony BDP-S360 DVD Player
Dynamic IP address
Dynamic ipaddress - is temporary, the ip changes when you disconnect for example.
Normal, or static ip - It's the same address from day to day.
May 19, 2008 | Computers & Internet
Have already described this probelm four times and paid for premium assistance. Hello????
if you have problem sir/mam just contact me. Reggie is your best contact solution to your problems.. Thanks
Mar 27, 2008 | Computers & Internet
Wireless internet hookup
What seems to be the problem of your wireless internet?
Laptop (Averatec Model #3150
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Mar 27, 2008 | Averatec 3150H Notebook
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
Does not bridge LAN and Wireless
ya need to check the ip add setting of acces point , as well as ssid , channel n region too. once ya log into the the routers configuration page , check that yor comp is getting the ip of same range/class from yor router, it might be liil different in the last number , no worries till then.... n assign the same ssid , region and security setting - like the secuirty key for wless to yor wless comps also. n calso check your comps are on dynamic ip settings. however if ya want to use the staic ip , then give yor comps a staic ip in the same range as yor router' range. n check the wzc service of yor windows xp or above system. it should be enable n running n should be usingthe same security key for wirless connection. or chat with me on samrat101, yahoomssgr or msn messnger samrat
Jul 10, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Televison & Video Logo
41 people viewed this question
Computer Repairing
Computer Repairing
