Code for ge vg2051 using rcrc36bgr - Televison & Video
We have a naxa converter box with a GE universal remote searching for the code
About 17,100 results (0.72 seconds) Search Results
    GE Universal Remote Codes and Instructions ' direcTutor
    www.directutor.com/content/ge-universal-remote-instructions
    Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will ...Missing: naxa
    Apex Digital TV Converter Box DT250 code ' ManualsOnline ...
    tv.manualsonline.com/support/...digital/tv-converter-box/code-1082992
    Nov 15, 2008 - Brock Search data: Universal remote control code apex dv converter... 4 I NEED CODE FOR APEX CONVERTER BOX FOR GE UNIVERSAL ...
    Trouble programming Universal Remote to a DTV Converter ...
    www.fixya.com/.../t2045188-trouble_programming_universal_remote_d...
    Apr 21, 2009 - So I'm trying to program my GE Universal Remote to work with my Digital Stream Converter Box but I can't find the codes to do it... If someone ...
    Control It All With Universal Remote Codes - Digital Landing '
Feb 08, 2016 | GE Televison & Video
I need help i have a GE universal remote RC430A Date code1636 I need to program the remote to the tv but i don't have the code. Please help.
Look inside the battery compartment and check the label. There may be a version code listed on that label. The GE remotes were manufactured by Jasco and the code lists are here: http://jascoproducts.com/support/ge-universal-remote-codes . Use the correct code list for the version for your remote. Note: these codes work for remotes sold in 2006 and later. For older GE remotes that use a 3-digit code, try this site: http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php .
I hope this helps.
(the remote control codes will often be limited to TVs that were sold at least 6 months before the remote was programmed. If your TV is newer than the remote, you may need to update your universal remote.)
Jul 10, 2015 | GE Televison & Video
How do I program my universal remote control for my ge tv model # 19gt357?
Code 000 for GE TV Code 003 for GE TV Code 004 for GE TV Code 006 for GE TV Code 022 for GE TV Code 052 for GE TV Code 054 for GE TV Code 055 for GE TV Code 064 for GE TV Code 087 for GE TV Code 100 for GE TV Code 165 for GE TV Code 166 for GE TV Code 167 for GE TV Code 181 for GE TV Code 203 for GE TV Code 212 for GE TV Code 233 for GE TV try these if these won't work add a 1 in front of the codes to give you a 4 digit code. Good luck
Nov 15, 2010 | GE 19GT357 19" TV
When I plug in GE Simon 3 panel it is already armed
Is your Simon 3 new or used? The default Utility Access Code 1 or 2 (i.e. the code you use when you open up the cover) is 654321, 54321, 4321 or 321. The default Master Access Code (i.e. the code you use to arm / disarm without opening the cover) is 123456, 12345, 1234, or 123. The length of the code depends on option 54. Default is 4 digits. If it's a used one that has non-default settings, you can reset memory to factory defaults.
Nov 17, 2009 | GE Security Simon 3 Wireless Home Security...
What is the remote control code for use with other universal remotes?
is the other way around , different brands of universal controls , different codes for your GE , THANKS AJ
May 28, 2009 | GE 25GT240 25" TV
Durabrand tv model#BH2004D need code for GE universal remote
The code for GE universal remote for th Durabrand BH2004D is "0157"
May 07, 2009 | Philips (PM625S) Remote Control
General electric Universal remote control codes
i lost my code book for my ge remote control
Apr 11, 2008 | Broksonic CTVG-5463GVC 19" TV
CODE
Hi
you can get the codes for GE remotes from here
Good luck, and thnaks for using FixYa. A FixYa rating would be awesome for helping you out:)
regards
robotek
Feb 18, 2008 | GE RM24906 Remote Control
Universal remote
Click Here
For the 4 digit Universal Remote Code List From GE (suppose to work with all GE Universal Remotes as long as they use 4 digits to program.)
Click Here
For the 3 digit Universal Remote Code List from GE (uses 3 digits to program, unless the remote was purchased before August of 2002)
Click Here
For the 3 digit Universal Remote Code List from GE if your remote was purchased before August of 2002.
Oct 28, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
