Question about Sharp AR-M205 Copier
Sharp mx3501N f1-00 code repair - Sharp AR-M205 Copier
2 Suggested Answers
  • 24 Answers
SOURCE: What is error code FK3 on Sharp MX3501N
FK3 is the code for the cleaning web in the Fusing Unit.
Posted on Aug 04, 2012
I have a printer SHARP MX3501N and came today in the office and Error code h3-02 is being displayed.
Your thermistor in your fusing section has gone bad. Or is weak , should be replaced or cleaned.
Mar 22, 2017 | Sharp Mx-3501n Copier Color Mx3501n...
Error code h3-02 SHARP MX3501N
fuser temp is exceeds specified level-your firmware needs to be updated.
Error code h3-02 ( sharp mx3501n)
There is a problem with the sub-fuser thermistor, should be cleaned or replaced. Use simulation 14 to cancel problem.
Jul 30, 2012 | Sharp MX-2300N Color Copier
We have a sharp mx3501n printer. Whenever I print from Photoshop CS2 the prints are horrible. Any suggestions for color profiles/settings that might make this better. Should I be using a CMYK file in...
Definately CMYK so you can see which colors are out of gamut. If copies are lousy too, then you might have old supplies in the machine. In service sim mode (type # * C *) go to 64-5 and print the test charts directly from the print engine. You should get one greyscale and one color page. If those look bad, then you need a supply change (drum, developer, or belts). In the driver under Printing preferences you have the option to set color schemes until you find one that works. If you still have trouble, get a new driver from www.sharpusa.com, past that a firmware flash may be necessary.
Jan 25, 2011 | Sharp MX-3501N All-In-One Printer
How to connect a sharp printer mx3501N to a network
the best way is to hook up the copier to the closet router set the machine to dhcp let it assign a ip address and install drivers, etc...
Nov 04, 2009 | Sharp MX-3501N All-In-One Printer
Call for service
There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
OR
put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, removed the old bk toner and put back the original bk toner u had removed.
that should fix
May 13, 2009 | Sharp MX-3501N All-In-One Printer
Error code on copier
The error code and clicking are both fuser related. The clicking is caused by the fuser bearings. Sharp has made several changes to the design of the fuser roller and added then subtracted some extra washers. It has been a problem for some time. Changing out the bearings may get rid of the noise for a while but ideally you would want to change out the rollers(new style) and bearings in one go.
H4-02 indicates a heating problem in the fuser. operating temperature is not reached in a specified time. You could pull out the fuser unit and take it apart to make sure the thermistors that are touching the rollers are clean and also check the thermostats. clean any debris. It could also possibly be a board or heater lamp issue (maybe..).
Clear the code in SIM mode by pressing the following keys one after the other "P" "*" "C" "*" and then enter 14 and and "start" key and execute. if copier does not reboot automatically then press the CA key couple of times.
Apr 02, 2009 | Sharp Office Equipment & Supplies
How to scan using a sharp mx3501n?
as long as your machine has been configured within the network settings. press the image send key then addres book then enter your email or select the folder or email addres to send it to.
Dec 02, 2008 | Office Equipment & Supplies
Sharp AR-M205 Copier Logo
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
