Question about Royal Ex3 Digital Scale 3lb Capacity Used
Royal ex3 scale
Won't work - when I turn it on, it just get broken lines
2 Suggested Answers
wwstudio2
SOURCE: i have the royal ex3 digital scale and when i turn
i just started using it had experienced same.
first, turn them both on. don't put anything on the scale yet.
when you see the -- -- --, press "tare" until zeroes appear.
then you can place things on the scale.
mine started with the symbol lb and the ounces was a percentage (.45)
to fix that, press lb/oz until you can see lbs and oz after each number,
Posted on Aug 24, 2012
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Starts up beeps put somehing on it and it dosn't weigh
The pressure sensor under the platform is probably corroded or broken...it may not be economic to replace it...buy a new scale.
Jan 13, 2013 | Royal Postal Scale Gray
Can i replace the battery in my Royal EX2 Exacta Scales Postal scale?
90 day warranty on this scale to begin with so when battery dies after 10 years, you have no warranty to preserve. Royal EX2 Exacta Scale - royalsupplies.com - manual downloadable.
You will need a Phillips #1 and I think a #0 for best fit. 2032 lithium coin battery (fresh, so it will last another 10 years). 1) Peel off large label from bottom (Xacto knife to get under a corner). 2) Remove 3 screws attaching pan to mechanism. Use magnitized P0 screwdriver here. 3) Remove 4 rubber feet, and four P1 screws under them. 4) Opposite side of display from the button is the black battery case. Use P0 screwdriver to remove three screws. Replace battery. 5) Put back together...
Don't mess with the mechanism inside (at least not if you want a calibrated scale) any more than you have to while changing the battery.
Jul 04, 2012 | Health & Beauty
Yamaha royal star xvz 1300 won't idle without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
OEM parts for Yamaha
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
I have 2001 Buick Regal where when the heater/ac is turned on you can hear the fan work but the vent won't open and close.
When you say that the "vent won't open and close" do you mean that the mode control is stuck on defrost - no matter which position you put the switch in? If this is the case, you most likely have a broken vacuum line in your engine compartment. You will find a plastic vacuum line going through your firewall. This line connects to the intake manifold on your engine. I can't tell you exactly where, because the service manual doesn't actually say and also you forgot to mention which engine you have. You will find it if you look for it. The plastic line is most likely broken. This can be fixed by using a small piece of rubber vacuum tubing to "splice" the line back together.
Oct 04, 2011 | 2001 Buick Regal
I have the royal ex3 digital scale and when i turn it on it just shows - - - - how do i fix it ?
I am having the same problem with my Royal ex3....changed the battery, but when I turn it on, all I get is - - - -
Anyone know what this means or how to fix it??
Jun 30, 2011 | Royal 17014c 10 lb Digital Postal Scale
I ran a cycle of vinegar through special edition brewer and it continues to say de-scale after doing scaling. it won't pour water sometimes and has to be turned on and off to get it to pour water. ...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Jun 14, 2011 | Keurig Platinum B70 Coffee Maker
My Royal ex310 shippping scale is not reading correctly. Can I recalibrate it? Thanks
my royal ex310 will not reset. I turn it on, and the 8's just flash! changed batteries to no avail. help!
Nov 23, 2010 | Kitchen Appliances - Others
Royal Ex3 Digital Scale 3lb Capacity Used Logo
29 people viewed this question
Top Royal Health & Beauty Experts
Colin Stickland
Colin Stickland
Susan Poche
Susan Poche
Tammy Husk
Level 1 Expert
Are you a Royal Health and Beauty Expert? Answer questions, earn points and help others
