Question about Porter Cable Palm Grip R.O.S. With Kit Box Part No. 332K
I have a porter cable 5" r.o.s. that is not orbiting. what is the most common resolution to this problem?
  • 2,176 Answers
It could be the bearing in the eccentric. If you provide the model number I will see what I can do to exactly narrow it down. But you can try turning the pad by hand and should feel some resistance and the motor not turn, if it does I would think the bearing or something rubbing on the housing.
Posted on Feb 01, 2009
How do I remove the rotating disk on a porter cable polisher model 7336
You have to use a wrench behind the disk for a stop and then unscrew from the housing Porter Cable
Feb 23, 2013 | Porter Cable Porter-Cable Variable Speed...
I have a Mastercraft random orbital sander Model 54-7206-2 and need a dust bag. Is it available, how much, and how do I order it in Canada?
I just had the same problem. I couldnt find any information online.
call the toll-free help line
1800-689-9928
Tell them the make of the sander and what kind of part you need. They will look it up and ship it to you in 7-10 business days
Feb 20, 2011 | Porter Cable Porter-Cable Variable Speed...
My 5" random orbit sander model 333 is spinning out of control. What do I do?
I may not have the whole picture, but all random orbits spin wildly if they are not pressed onto the wood a little. Do you mean it is not oscellating, but just spinning when it is on the wood? That would be an issue requiring cleaning or repair, otherwise, just don't turn it on until you have placed it on the wood to avoid marring.
Farmerbear:)
Sep 07, 2010 | Porter Cable Random Orbital Sander, 5"
My porter cable 5" random orbit sander will not do any thing no nothing help
first check your cord. volt ohm meter for continuity. check the brushes, not worn down and move up and down. check the switch with the volt ohm meter.
Aug 31, 2010 | Porter Cable Palm Grip R.O.S. With Kit Box...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
I have a porter cable 5" ros that is not orbiting
If it is not orbiting I would look at the bearing in the eccentric under the pad to make sure not seized up or other problem. Also look at the screw holding everything together. Let me know with the exact model number and brand if still a problem and I will dig deeper into this.
Jan 27, 2009 | Porter Cable Palm Grip R.O.S. With Kit Box...
Need help disassembling Porter Cable random orbit sander
Go to Dewaltservicenet.com and in the center of the page under needing parts type in your tool model number it will take you to another page and scroll down to the type 1 or 2 and click on it. It will bring up an exploded view of this tool. Why do you think that you need brushes? usually I have to replace the bearings and the brushes are pretty durable. Let me know if I can help further
Jan 19, 2009 | Porter Cable 332K Quicksand Random Orbit...
Porter Cable Palm Grip R.O.S. With Kit Box Part No. 332K Logo
102 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
