Question about Canon PIXMA MP160 All-In-One InkJet Printer
Grab paper hi, i have a canon mp 180 copier,scanner machine purchased in 04/07. everytime i try to feed paper into machine to copy, the paper gets grabbed from one side & won't feed through. any suggestions please?
  • moford Jan 29, 2009
    THANK YOU VERY MUCH.
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I have a cannon mp 240 bought it 7 months ago have barely used it, just purchased 1st set of ink cartriges. have printed maybe 4 pages since replacing.. Now says out of paper, wont feed sheets in. help!!
Check the rollers that feed the printer paper through. Use compressed air to clean out the printer and rubbing alcohol on the rollers once you clean them. If the rollers aren't grabbing the paper, then maybe a gear is not working properly.
Canon offers a one year warranty, take the printer in and get them to service it instead of trying to fix the problem yourself.
Sep 01, 2009 | Office Equipment & Supplies
The paper starts to feed on the canon pixma mp 160 but when i try to print or copy, paper doesn't continue to feed and I get an E message. any suggestions
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-7
Aug 17, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper keeps getting jammed in MP460
I had the same paper feed grabbing problem on pixma MP 610 printers - take a flashlight and look down into the feed rollers inside - deep - I found a paperclip in one and a hair clip in another - you need a pair of very fine pincer pliers to extract so you dont damage the roller assembly's made of plastic - and voila no more misfeeds and grabbing on the right side - hint - dont put anything on top of the printers because when you lift the scanner cover, it nicely slides anyting on top into the paper feed assembly and results in a jam
Steve
Aug 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer will not feed paper / message E2 ...cannon pixma mp 160
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
someone replied to my problem, i tried it and its fixed 1st time, for others its taken a few attempts and then worked..
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now. hope this helps, let me know how you get on. Garty
May 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper feed broken
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Mar 20, 2008 | Canon ImageClass MF5770 Laser Copier...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
98 people viewed this question
old marine
old marine
