Question about Kenmore Washing Machines
Kenmore 80 8530442
Will not drain after wash cycle
SOURCE: Kenmore washing machine won't drain
I went to the LIBRARY and checked out a book on Washing Machine Repairs. It had all types of makes and models of washers. The book listed problems that can occur and solutions with complete diagrams of all the parts how to take the machine apart and put the replacement part in and put the machine back together. This all in a book I checked out from the local LIBRARY FREE of CHARGE. I'm going to spread the word that you don't have to pay for information on anything, JUST GO TO THE LOCAL LIBRARY. What a wonderful service they offer to all citizens.
Posted on Jun 26, 2008
BNewberry
  • 93 Answers
SOURCE: Kenmore 90 series will drain but not spin
You definitely have a broken motor coupling. This is the piece that connects the motor to the trasmission. The pump is connected directly to the motor on the other side opposite of the coupler. When they break, the water will drain but the washer will not spin.
Here is a repair manual that will help you replace the motor coupler.
If you have anymore questions please ask. This is an inexpensive repair and something you can do yourself. Just refer to the coupler in the manual and you won't have any issues.
Thanks
Posted on Jan 12, 2009
  • 1214 Answers
SOURCE: Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Posted on Jan 22, 2009
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
My kenmore top load washing machine washes but wont drain or spin
The spinning cycle may be detecting that your tub is unbalanced and will not proceed. Check that it starts and fails when the tub is spinning slowly. Otherwise you may have a faulty drain relay or debris is plugging the drain out hose.
Feb 01, 2015 | Kenmore Washing Machines
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore Model @16969990 Washing water doesn't pump out, cycle doesn't finish, attemptes to run other cycles default to "normal wash"
The drain cycle does not complete as the drain pump is not working the pump out the water. So unless the drain level comes down to reset the water level controller the program does not progress further.
So check the voltage during the drain cycle if voltage is present then the drain pump is faulty if not the main controller is faulty.
replace accordingly.
Sep 17, 2010 | Kenmore Dishwashers
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
