Question about Saws
Need manual for Craftsman model 103.21840 tilt arbor saw
  • 15 Answers
SOURCE: truing craftsman table saw blade
Use a carpenter square to allign the blade both vertically and horizontally with your guide. This works very well.
Posted on Jan 28, 2009
frcs68
  • 1605 Answers
SOURCE: How do you remove the arbor assembly on a craftsman 10" table saw
go to sears service center and get a new arbor, and ask them to show you the motor and arbor assembly drawing. it should show how the arbor is attached to the shaft.
you can pull the arbor off with a pulley. you can get that from auto parts store.
Posted on Apr 13, 2009
Schmead10
  • 650 Answers
SOURCE: Need Owners manual for older Craftsman Radial Arm
Here is a site to have the manual Emailed to you
http://www.sawmanuals.com/ Hope this works for you.....Please rate.......
Posted on Apr 14, 2009
efs_perpends
  • 1996 Answers
SOURCE: crafstman radial arm saw owners manual model #113-29440
Go to this link and you'll be able to download the pdf file of the operating instructions for you saw.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 11, 2009
protek480
  • 1714 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
Posted on Sep 22, 2009
I need both pullys for the motor and the arbor. They are cast alu and need to be replaced.
call Sears,Have model and serial number ready,ask for parts and service,they sell any part for any craftsman power tool .
Jun 14, 2011 | Craftsman 10" Table Saw
I have a radial arm saw model 113.19790 I have no manual, I can't tell if it is 220 or 110 volts. It runs slow, can you tell me if this model is 220 or 110 volts. Thank You,,,, Denny
Craftsman Radial Arm Saw, model # 113.19790 requires 220 Vac. I purchased my saw brand new and I have yet to have a problem with it beyond typical alignments. My only complaint is with the 5/8" arbor.
Aug 16, 2010 | Craftsman Saws
I bought a used Jet Equipment and Tool Tilting Arbor Table Saw - CTAS-10-LFR. It stated once but now will not start. How do I locate a user manual?
Jet's manual site is here. I didn't find that exact model number. It might be worth double checking.
If this post was useful, please vote. Thanks!
Apr 06, 2010 | Jet Saws
Recently I cleaned and lubricated my 4 year old Craftsman cast iron table saw. I did such a good job that I created a problem which I never had. When I am running with a dado blades, the arbor will slowly...
There should be a locking knob on the front of the crank or a locking collar behind the crank depending on which model or age of the saw that you need to tighten down to lock the arbor height.
Feb 13, 2010 | Craftsman 10" Table Saw
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
Nov 19, 2009 | Sears Saws
Rear pulley arbor to short
Got bad news from Sears on this one, they say there are no serviceable parts for this tool and to contact them. Sorry I couldn't help more.
Jun 22, 2009 | Craftsman Saws
Mar 31, 2009 | Craftsman 10" Table Saw
Fitting a craftsmans 12" compound saw
Theres no fix here-if you want a laser, you'll need to get one that will fit the Craftsman.
Dec 02, 2007 | Irwin Miter Saw Laser Guide Attachment...
Saws Logo
91 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
