Question about Reddy Heater-30-55,000 BTU Variable
Reddy heater runs then stops
Placed evey part besides the fuel filter the nozzle is getting kerosene through it but wont light up. Does any one know the problem? Replaced the following parts-rotor, nozzle eye,plug,filters.
  • degranola Jan 27, 2009
    ignitor? Does the R50 Reddy Heater have one? Is *** the transformer?
  • 181 Answers
What is your air pressure.spark is spark as long as you have one the unit will fire.if you don't have enough or to much pressure the unit will not fire.check air line from air pump to nozzle assy.
Posted on Feb 17, 2009
  • 92 Answers
It's the ignitor itself, if everythingelse is working or new then your just not getting enough spark. Also check your air lines as they do tend to get brittle and if your not getting enough air it won't light either.
Posted on Jan 27, 2009
Bought a new ignitor, but it doesn't ignite
Is fuel getting to the nozzle? With the top of the heater removed, use a flashlight to look for fuel spraying from the nozzle. If it isn't, check the fuel filter. Have you check you air pressure going to the fuel nozzle? The required pressure should be listed on the data plate of the heater. If you can't get the air pressure right, your air filter could be the problem. Let me know what you find if this doesn't fix it.
Dec 27, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When I turn my reddy heater on model R115d(t) the fan cycle for approximatley 5 seconds then stops. The glow plug is getting red but no fuel. What could cause this?
Could be a dirty air filter. Fuel nozzle could be clogged. Fuel filter clogged, if it has one. Some don't. Could be a problem with the low pressure compressor that is attached to back of the fan motor.
Dec 22, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
My heater is a reddy heater 165,000btu. when i plug it up it will ignite, it will get a flame for about ten seconds and it shutdown. i recently replaced the ignitor because it broke and replace the fuel...
I would definitely stop burning off road diesel as it is dirty.Remove the top section of the heater and clean the fire eye with windex and a terry cloth rag, and run K1 kerosene it burns so much cleaner. Also make sure that fuel is not an issuecheck fuel filter,fuel lines and don't forget the screen in behind the nozzle.
Dec 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
The heeter stops after 10 sec evey time i have cleaned the air filliter and new flue
wendy425,
All Pro heaters and Reddy Heaters are the same.
This is a classic reddy heater problem. They use the bleed air to determine the pump pressure and ultimately the mix of the air/fuel. Once the filter gets dirty the relationship changes and the unit gets too much fuel. The solution is to get a new filter and the pressure gauge necessary to set the pressure after installing the new filter.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get the parts and how to complete the repair.
Thanks for using FixYa and the generous rating.
hardrocko
Sep 29, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater R 40
the fuel filter is dirty even if it dosent look like it,,they have a high particulate filter and they will stop up pretty quick if you have had a dirty fuel container or just a bad location that you purchased your fuel.
Jan 11, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Reddy Heater-30-55,000 BTU Variable Logo
335 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
