SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Hoover washer model VHD9143ZD
Have the same problem. Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF position. Select again the programme and press the START/PAUSE button to switch the machine back on.
We recall having this problem with a previous Hoover washing machine and it was solved by cleaning the filter. The service manual recommends you clean the filter once a month. The procedure is as follows:
1) Open the flap
2) Only available on certain models: Pullout the corrugated hose, remove the stopper and drain the water into a container.
3) Before removing the filter, place absorbent towel below the filter cap to collect the small amount of water likely to be inside the pump.
4) Turn the filter anti-clockwise until it stops in the vertical position. Remove and clean.
5) After cleaning, replace the filter and lock by tightening the filter screw. Then follow all procedures described above in reverse order.
Hope that helps :)
SOURCE: I have One and Half year old siemens
Check your water pressure, ensure that the valve on your machines water supply is fully open and that the hose is not kinked when you are pushing your machine into the wall. Also unscrew the water hose from the back of your machine (dissconnect the mains first) and check the filter for debris.
Hop this helps.
SOURCE: Siemens dishwasher error code E09?
dear sir
ther is an error (E17) my dishwasher model isSN25M230EU
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
