Question about Freezers
Manual required for telmann upright freezer tm002bf
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
Do you have a manual for a Frigidaire Freezer upright with model number FFU1464FW1
Hello Lasondra, that's a great question!
I have successfully located the Owner's Guide of your Frigidaire freezer, FFU1464FW1. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect! - Z
Frigidaire Manual Search Results
Sep 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need a user manual for a thermatech kbf2340 upright freezer
I would like manual for theramatech temperate upright freezer controls are on the front on the right hand side has pro & mute on one button arrow up with aux
other button has set def with arrow
Feb 14, 2014 | Freezers
My upright freezer runs more than it is off
general design requires compressor on off ratio to be total run time to be 18 hrs on per 24 hr day off time allows compressor to cool down averaged over the day cool air is required around the outer walls of the fridge to cool the condenser coil at the rear also
Oct 03, 2017 | Frigidaire Freezer Refrigeration White...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
How does the Frigidaire FFU1764 Upright Freezer defrost?
Download its manual here and then read through the defrost section. It should run every 12-24 hours.
Aug 23, 2012 | Frigidaire Freezer 16.7 Upright Freezer,...
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Is a Kenmore upright freezer model 253.23424102 frost free?
No it is not frost free. You can get the manual on the link below to read about the freezer and learn how to defrost.
http://www.managemylife.com/mmh/owner_manuals/134/KENMORE-Upright-Freezer-L0307021?brand_name_search=253.23424102+
Good Luck and please rate 4 thumbs up for the free answer.
Jul 26, 2010 | Kenmore Freezers
EXACT SAME PROBLEM AS DESCRIBED BY BETH_DESJARD ON JUN 07.2009 PROBLEM EXPLAINED, BUT NO SOLUTIION POSTED : WHEN I PRESS THE RELEASE BUTTON TO REPLACE THE FILTER IT DOES NOT RELEASE.
chances are,the actual filter mount itself is to blame,however the release button can sometimes require significant pressure to release the filter,so press hard...if required contact electrolux for assistance
Mar 10, 2010 | Frigidaire Freezer Refrigeration White...
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
