Question about Zebra LP 2844 Thermal Printer
Keeps printing the same label, button not working
My LP 2844p printer won't print labels all of the sudden. When I turn it off and on the button will work once and it will reprint this one label and then the button won't work anymore. I've tried reseting it (putting it in dump mode) to no avail. It will just go into dump mode and the button will stop working. I hope that makes sense even though it its entirely lacking in technical terms.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
When I print one label, the printer prints one label and send out two labels out. One is the printed one, the other one is empty. What's wrong with it?
  • Open the printer and remove the labels roll.Re-load it making sure its well fixed.
  • Turn the printer off.
  • Press and hold the green feed button and turn on the printer.Release button after the first flashing of led light.The printer will run a print test.
  • Turn it off and on again.
  • Now print.Problem solved?If not,
  • Open the printer[while still on]and disconnect power.
  • Close it and reconnect power.Turn it off and on again.
  • Now print.
Hope this helps.Thanks!
Oct 10, 2011 | Zebra LP 2844 Thermal Printer
Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
Apr 14, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 is stalling out on every print.
Maybe the printer is not getting a good calibration on the label. If the status LED is a steady RED when trying to print, then the printer thinks its out of labels. A manual calibrationi could solve that.
1. Turn the printer off
2. press and hold down the FEED key while turning on the printer.
3. keep pressing the key until the status light flashes once, then let go
4. The printer will auto-calibrate for the size of label and then should be ready to use.
Press FEED once after its done and 1 label should feed.
Hope that helps !
Apr 06, 2010 | Zebra LP 2844 Thermal Printer
Label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Alignment of print with Labels
Sid
Perform a media calibration as follows: -
Press and hold the green button and turn on the printer.
When the red flashes 3-4 times release the button and the printer shoould perform a calibration, then try printing again. Any futher problem with this contact Lancer labels
Apr 15, 2008 | Zebra LP 2844-Z Thermal Label Printer
Just installed my 2844
Bask11,
sounds like the printer needs to regap itself. Turn the printer off, hold the feed button down and while holding the feed button, turn the printer back on. As soon as it flashes, let go. It will regap itself. When it stops moving, press the feed button once and there should be a priinted line that says 'out of dump'. The printer should be ready to go then.
Mar 11, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
242 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
