Question about Parkzone Ultra Micro T-28 Trojan BNF
MOTOR PULSES AND WILL NOT RUN AT FULL THROTLE.NEW MOTOR DID NOT FIX THIS PROBLEM
Motor pulses on full power wash
It sounds like you either have a clogged nozzle or one that is too small for your pump. At lower speeds the pump is pumping less gpm. So your unloader valve does not cycle. Then when you go to full power. The engine is running faster and pumping more gallons per minute. The nozzle is too small or clogged and so the bypass opens and closes ( surges) Try a new nozzle that is the right size for your machine.
Oct 09, 2014 | Karcher 2500 PSI Pressure Washer
Running and starting difficulties
For what motor????????
Nov 10, 2013 | Boating
2006 Hawkeye sputters at full throtle. Take air boot and air cleaner off runs fine. put just air boot on it starts to sputter at full throtle. Not even the air cleaner just tube from carb to air clean
that might be the overflow tube and should not be hooked to anything, it's like a emergency drain for the carb and when you hooked it to the filter is pulling gas out of the carb at high motor speeds causing it to sputter .. jay
Aug 28, 2012 | Polaris ATV
Cant get running
computer problem??
Apr 14, 2010 | 1998 Dodge Ram 1500 4WD
Poulan bv200. will not throtle up. it starts with choke at1/2 and throtle at 1/2. new spark plug and clean air filter. when i try to zero choke it dies. and at full throtle it will not get to full speed...
The unit is lean. rebuild the carb with a carb kit and check your fuel lines. If they are brown or discolored or brittle they need to be replaced. carb kits run approx. 11 - 18 dollars from your local dealer.
Nov 23, 2009 | Poulan Garden
Ryobi 725 R runs only when choked, full throtle
you will have to rebuild carb.red and yellow caps just pull off you might have to get a tool to ajust carb and take them out
Jul 18, 2009 | Garden
Wiper Motor
Yeah I too had the same problem and its' the board...
age, moisture on board so spend about 15-25 bucks at the dealer and ....let it rain!!!
Aug 02, 2008 | 1992 Chevrolet K1500
Parkzone Ultra Micro T-28 Trojan BNF Logo
29 people viewed this question
Top Parkzone Toys Experts
ray gallant
Are you a Parkzone Toy Expert? Answer questions, earn points and help others
