Question about Samsung SCX Office Equipment & Supplies
Copier says no developer cartridge scx5115
Developer cartridge is installed yet says no developer cartridge
2 Suggested Answers
tehnik_bdg
  • 91 Answers
SOURCE: blank copies on an ar208s sharp copier
Inside this machine has 3 sections. Toner cartridge, developing unit and drum unit. First pull out the toner cartridge then you will see a blue anodized screw, loosen this screw then pull this section ( developing unit ), if there's already toner inside the chamber, clean it and pour the all the developer into the chamber then put back the developing section, tighten the blue screw and install the toner cartridge.
Posted on May 13, 2009
How do i solve the developer unit is not installed?
This can actually be caused be a low toner condition. Open cover and remove the developing unit. Next, release the blue lever and remove the toner cartridge. If it feels empty, replace with a new cartridge. If it appears to still be partially full, re-seat the cartridge into the developing unit and gently shake side to side. Reinstall the developing unit and close the lid.
Jul 28, 2015 | Kyocera FS-1135MFP
My kyocera fs-1370dn suddenly says it is missing a developer unit
The developing unit is where the toner sits upon.Remove the toner cartridge and ensure that the developer unit is correctly inserted.Then re-instal the toner cartridge.
Mar 12, 2015 | Kyocera Office Equipment & Supplies
I installed new toner and now it states call for service F2-04
F2-04 means that the IC chip on the end of the toner has been blown by the copier due to the fact that for X-period after attempting to , the copier was unable to replenish the toner level in the developer unit, there may be various problems leading to this, most common is that the gears on developer unit was stripped, or toner motor is no longer functioning, or that the magnetic sensor on the bottom of the developer unit is coated by a layer of toner of compacted developer or toner, or you used the wrong cartridge, either way , F2-04 is usually indicative of something worse than expected, my professional opinion on this one is to send it in for repairs by a qualified service technician.
May 27, 2014 | Sharp AR-M257 Black and White Copier
I have sharp AR-5316e and it has CH error non function are working.
CH
ON
None Content Side door open
Detail The side door is open.
Cause Side door sensor abnormality
MCU PWB abnormality
Check
and
remedy
Check that all the side doors are closed.
Replace the MCU PWB.
CH
Blink
None Content Developing cartridge not installed
Detail The developing cartridge is not installed.
Communication with the CRUM cannot be
made in initial check of the CRUM.
Cause Developing unit disconnection
MCU PWB abnormality
CRUM chip abnormality
Check
and
remedy
Check installation of the developing unit.
Replace the MCU
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
How do i change/refill the developer on a SHARP AR M257 copier?
open frount cover remove toner cartridge. remove blue screw be carefull dont damage drum.developer unit out ,clean old developer and apply new developer .then re install all of them and input code 25-2 and let the copier to run and stop automaticly.
May 17, 2010 | Sharp AR-M257 Black and White Copier
When installing a toner/developer cartridge in a sharp Z-57 copier is there a reset procedure to follow?
If there is the instructions on when and how to perform a reset will be included with the toner/developer cartridge.
Sep 04, 2009 | Sharp AR-5316 Advanced Digital Imager...
Blank copies on an ar208s sharp copier
May 12, 2009 | Sharp AR208s copier AR208s All-In-One...
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Nov 11, 2008 | Office Equipment & Supplies
Adding developer
If you buy a new toner cartridge the developer is already in it.
Are you mixing ink and toner to rebuild cartridges?
If your just a user, once you replace the toner cartridge you have added new ink with the developer in it.
If you are not mixing and rebuilding the toner cartridge, and installing a new one, You do not need developer.
Apr 03, 2008 | Sharp AL 1631 Copier
Add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Dec 30, 2007 | Sharp AR-5316 Advanced Digital Imager...
46 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
