Question about Sentry FIRE-SAFE Combination Safe DS3431, DS3431
Sentry safe g2459e factory code - Sentry FIRE-SAFE Combination Safe DS3431, DS3431
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How do I open a sentry s3877 safe when the battery is dead and safe is closed
    The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
    If you do not know your factory code, you can follow this link for your combination retrieval:
    http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
    Sep 23, 2012 | Sentry Fireproof Safe
    Lost factory code for sentry safe model #d8W5840
    did you ever find the factory code? I lost mine also. if you have the factory code for this model please message me on facebook.com/vernhartjr
    Sep 09, 2012 | Sentry Safe Sentry Fire-Safe Combination...
    Lost factory code
    hi.
    the factory code for sentry safes would normally be 00000.
    if this does not work you may have to contact Sentry with the safe model and serial number .
    these are normally found on a label on the back of the safe, or a label on the front edge of the safe.
    contact details for sentry can be found on www.sentrysafe.co.uk
    hope this helps
    Mar 26, 2011 | Sentry Security Safe with Electronic Lock...
    I have a sentry safe model s0310 i lost my combination but i have the key but it doesnt work how do i open it!
    Hi Juli, if you still have the manual, there is a factory code printed on the beginning page and that code can be used if you forgot your code. The factory code can never be deleted. If you dont have your manual anymore then the only other option is to call the company and they might be able to give you the factory code somehow.
    Sentry Safe Customer Service - 1-800-828-1438
    Feb 12, 2011 | Sentry Fireproof Safe
    We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
    Dec 07, 2010 | Sentry Fireproof Safe
    Lost codes
    would you know the factory recovery code for sentry 1610 as
    i lost it or it is locked in my safe. My battery has been dead
    for some time and I think it lost it's memory.
    Jul 17, 2009 | Sentry Fireproof Safe
    Need to open a Sentry keyless combination safe
    First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
    If the factory combination has been changed to something else, then Sentry won't have it.
    In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
    The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
    You can take it from there.
    Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
    They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
    Get 'hold of Sentry on the web and the rest is just process.
    BTW -- this is exactly what the locksmith would do.
    Apr 10, 2009 | Sentry Fireproof Safe
    Sep 29, 2008 | Sentry Fireproof Safe
    Sentry FIRE-SAFE Combination Safe DS3431, DS3431 Logo
    41 people viewed this question
    Top Sentry Home Security Experts
    Jim London
    Jim London
    Computer Repairing
    Computer Repairing
     Brian Main
    Brian Main
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
