Question about Aprilaire 550 Humidifier
Need to shut off aprilaire model 550 humidifier
This is supposed to be fairly simple I am told - does anyone know how?
    Problem Solver:
  • 17 Answers
You should have a humidistat that should shut it off when set to zero. if the water solenoid is stuck, water will keep coming out even when the system is not heating. all humdifiers will have a water line ran to them. yours is most likely a 1/4"copper line that runs from the water solenoid on the side or bottom of the humidifier to a saddle valve on one of your water lines. this saddle valve is usually installed very close to the water heater. follow the line to the valve and shut the water off. sometimes you have to loosed the nut on the water valve to get it to turn easily. do not loosend the nut more the 1/4 turn and then make sure you tighten it back down after shutting the water off.
Posted on Jan 27, 2009
How do I shut the water off to my Aprilaire 550
Hi follow the water line from the water valve back to the cold inlet pipe should be a tap on there
Jan 21, 2010 | Aprilaire 550 Humidifier
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
How do I know if my Aprilaire 550 humidifier is working?
Should the water flow through the water pannel al the time the blower is running?
Nov 27, 2009 | Humidifiers
We have an old Aprilaire humidifier (Manual adjust)and having problems trying to figure out how to shut it off-for the summer.
close the by pass air flow valve. shut off the water supply and finally flow the thermostat wire to the transformer or the controller and shut off or disconnect. Unit should be serviced before winter. Cell may need to be replaced
Aug 10, 2009 | Aprilaire 550 Humidifier
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
I have a Aprilaire 550 Humidifier. The feed tube is cracked and leaking. How do I go about replacing it. When I use a wrench to remove the copper end, will water come pouring out?
Thanks for your question,
what you need is called an ( Ice maker kit ) any hardware store or appliance store should carry these, the copper tubing is 1/4 in, the kit comes with the service valve for turning on the water once installed, be careful, turning it on before the line is hooked will get ya soaked, it has compression fittings, make sure you dont cross thread the nuts when installing, you may have to shut the main water supply off to the house before doing this, the instructions are fairly easy to read, you can get 25ft - 100ft ice maker kits, you are going to need a tubing cutter and a cresent or box end wrench, and a big flat head screw driver, hope that help ya, lets us know, thanks again for the question,
Jan 05, 2009 | Aprilaire 550 Humidifier
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
Nov 20, 2007 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
334 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
