Question about IBM Lexmark Z715 InkJet Printer
I changed the black ink cartridge and it only prints yellow.
My color cartridge is in need of changing but I don't have one and I need to print out a boarding pass.
  • 2,120 Answers
No way to get around it.
Posted on Jan 27, 2009
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Canon IP4300 - the two black ink cartridges
The large cartridge is used for text only printing.
The smaller black cartridge is used for black in images such as pictures.
You have a "C (cyan) M (magenta) Y (yellow) and B (black) color system. This actually saves the color inks for you. If the Black was not there, you would need to make a composite black from the color inks.
Jan 31, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Brother DCP-145C Print in black and white..?
As far as i know it will not work for color print unless all the cartridges are full. It will still print in b&w- go to properties of your printing document and change to "greystyle" but this will only work if you don't/have not turned off the machine at the power point. Once the machine is reset it wants to confirm all new cartridges and wont allow a black print until they are all in and full. So you cant use cartridges that have run out to "trick it".
I'm not sure if this is the intent of brother ( my guess is yes) a design oversight or a genuine precaution measure for consistency by not letting the printing heads dry out.
The yellow always runs out first, so stock up on them if you do alot of color printing- but the cartridges only last for 6 months so don't go crazy.
Brother if your reading this- Most of us don't care about color~! We just need a printer for uni and information. Make it work on our price range please!
Apr 29, 2009 | Brother Office Equipment & Supplies
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
IBM Lexmark Z715 InkJet Printer Logo
80 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
