Question about Refrigerators
Westinghouse BJ 513V-R freezer warning light comes on at irregular intervals
  • Refrigerators Master
  • 19,396 Answers
You need to unplug the freezer and leave it to defrost completely.
If the warning light comes afterward, that means that there is a fault, in that case you should call a technician.
Posted on Jan 27, 2009
    Genius:
  • 1,847 Answers
  • Legin Varghese
    Legin Varghese Jan 27, 2009
    just go through the checks and let me know if you need further assistance. Kevin
    Sergeant:
    Novelist:
  • 326 Answers
This can be due to some faulty connections or some problem with the freezing unit.the unit must be opened and checked overall to see what is faulty.
I have a westinghouse frdge freezer bj 385 motor constantly running with the door close motor stops intermidently open door motor stops recently moved fridge
Hi Peter, It it's not freezing the fridge up then it needs regassing but it it's freezing the fridge up then could be the thermostat, Good luck mate..... CHEERS..
Apr 04, 2016 | Westinghouse Refrigerators
My Westinghouse freezer has an alarm beep that goes off every now and then and the only way to stop it is to turn off the fridge completely. In the fridge section the temperature panel flashes the...
Often these have door alarms. If the door isn't completely sealed shut then it will alarm and cause the temperature/thermostat to blink to warn of "warm" temperature inside the fridge
Mar 04, 2015 | Westinghouse Refrigerators
Westinghouse wse7000sa freezer light exploded and now fridge isn't working
Please recheck that model number. It is coming up as a washer.
Dec 02, 2012 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Freezer icing up on roof and door corner.
yes, sealing problem. take a hair dryer and see if can smooth out corners. do not hold stationary on gasket. move slowly back and forth. make sure not gaps around gasket. warm air is the problem
Mar 04, 2010 | Refrigerators
Lots of water in bottom of refrigerator
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
Apr 02, 2009 | Estate TT14DKXKQ Top Freezer Refrigerator
Fridge intermittently bangs like very loud champagne cork popping
Sometimes when fridge first starts they can sound like water dripping into hot oil or deep fryer, this is caused by liquid refrigerant returning to compressor which has hot oil in sump, this is normal and no need for alarm, unless the fridge is not keeping temperature.
Nov 04, 2008 | Refrigerators
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
