Question about Brinks 1-1/2 In. Brass Combination Resettable Padlock
I need to reset my lock's number code, My old numbers no longer work
Forgot password for facebook and no longer have access to old contact number. how do i change number to receive a code to reset password?
Go to your face book and type your number that you were using before and the click on the link that says FORGOT PASSWORD and they will send you the code to reset password
Jan 09, 2014 | Facebook Social Network
Forgot my lock code and I don't know my ime number and ant get through the turn on stage what can I do
Hi,whats your mobile brand and model?
If it is Nokia,try default security code like 0000 or 1234 or 12345 .If it does not works reset your phone by using the Master Reset Code.To get this code at free of cost visit the site Unlock-Free.com here they are providing this Code for some old model Nokia DCT and Alcatel old phones and reset.There you need to specify your Model and IMEI number of your phone.
Note:The IMEI number of your phone can be found printed on the phone underneath the battery.
Aug 01, 2013 | Cell Phones
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
My tv is locked blue screen with red lock box how do i unlock it
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary
Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off
Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
Apr 24, 2012 | Jensen Televison & Video
How i bypass security lock
try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. If your phone is either nokia or alcatel, You can get the master reset codes from Unlocking4U.com
Apr 16, 2012 | Cell Phones
Need tv code, tv is locked
5
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
I bught nokia 5310 i want to lock the phone.but i dont know old password.
Hi, try the default code 12345 and if it still doesn't work, you can unlock it very quickly and easily from these sites: www.mobileunlockguide.com www.unlocking4u.com or www.theunlockarena.com
Note: unlocking is not free, You will be charged to get your unlock code. The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code/master reset code. You can try master reset but your files will be lost dear if you haven't backed it up...(you can use any of your friend's phone to make this call) You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone. Then they will provide you the instructions on how to enter the codes. Hope this can help you,GoodLuck =)
Aug 15, 2011 | Nokia 5310 Cellular Phone
My 10 v old daughter decided to play w my phone she put some kind of code and she dont remember what she did when i try to use it . it says lock code requried what do i do
I'd try the last 4 digits of your phone number, 0000, or 1234.
If that doesn't work, you'll have to perform a master reset, which will remove all your settings, contacts and messages.
The master reset option is in your settings menu somewhere.
May 05, 2011 | Sanyo SCP-2700 Cell Phone
Forgot lock code on LG EnV, need to reset settings for donation
I had the same issue with the same phone. By pure luck, I tried the last 4 digits of the phone number last used on the phone and it worked!
Feb 09, 2010 | LG enV VX9900 Cellular Phone
My 9 year old son was playing with my phone and changed the language to Spanish. In an effort to reset the phone we took the battery off and put it back on and turned the phone on. The phone was still in...
Verizon advised you to commit insurance fraud? There is a new telephone for you!!!! And someone's A**
Did Verizon try the hard reset? I dont know what language is default but presume a phone headed to the USA market would be English.
Since you tried the default code (the last 4 numbers of your number and failed, I presume you changed it. Still, a hard reset should clear everything.
I think Id be talking to the Verizon store manager or his boss about the insurance fraud advice.
Good luck and I hope this resolves.
Oct 18, 2009 | Casio G''zOne Type S Cellular Phone
Brinks 1-1/2 In. Brass Combination Resettable Padlock Logo
35 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
