Question about Yamaha Full-Size Keyboard
Yamaha v50 keyboard won't boot up
When i turn on my yamaha v50 it keep cycling through the intial start up, will not go into the play mode tried to reset by holding (seq - card - demo) nothing happens.
any suggestions on repair?
The 2013 button battery must be replaced to boot up. You should find or make a battery holder with two leads to replace the soldered in battery.
Posted on Jul 22, 2009
Dunno...make sure that there is no disk in the drive on re-boot
Posted on Feb 08, 2009
My Yamaha psr e303 all keys from bass side stop playing what can I do?
You might have the accomp switch turned on?
If not try holding down the highest key whilst turning the keyboard on, this will start a factory reset.
Sep 18, 2016 | Yamaha Music
Yamaha YPT 400: ALL re are not working
Hi, If by "re" not working you mean note D then try the following.
Keyboard off, hold down top C key while turning on. This factory resets. Does D key now work - if not. Has it ever worked - if not then it could possibly be the ribbon connector between the keyboard and the motherboard. If one of the cables gets bent then this would stop all notes associated with that connection to stop working. This will only have occured if the keyboard has never played these notes or if it has been taken apart.
You could also try the self test mode : Keyboard off, hold C#,F, G# in the 2nd octave up whilst turning on, cycle through tests to sound if it plays all the notes one at a time then the sound chip is ok and it points to keyboard switching. If test mode does not come up in 2nd octave try 3rd octave ( cant remember which one it is from memory )
Let me know how you get on.
yamaha-ypt-400-all-re-not-working#solution-section-o0etyz1v3mt3zyequ52mc4su-5-2_0.jpg
Feb 07, 2016 | Yamaha YPT-320 Keyboard
Yamaha v50 touch response
how to activate touch response Yamaha v 50
Oct 25, 2012 | Yamaha Full-Size Keyboard
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
Yamaha 88 key piano grand plays wrong pitches w/ changing volume
If it has a sequencer/ recorder built in, you have the ability to change the pitch/ detune by using some key strokes after initiating the program mode. If your not sure how to do that, try unplugging the keyboard for thirty seconds and push the power button while it's unplugged, then plug it back in. Any better? What model is it.
Jan 01, 2018 | Yamaha Full-Size Keyboard
V50 YAMAHA WITH NO PERFORMANCE SOUNDS ANY MORE
Check this link out....lots of helpful info re: v50. Sam
http://www.yamahaforums.co.uk/modules.php?name=Forums&file=viewtopic&t=2460
Feb 12, 2009 | Yamaha Full-Size Keyboard
Yamaha psr230 keyboard wont turn on
I was bird so I got on my yamaha won"t I c it and it don"t turn on
Oct 19, 2008 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
968 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
