Question about Panasonic PT-AE900U Multimedia Projector
Panasonic PTAE 900U with new lamp and counter reset shut off
I replace lamp, reset the counter but the projector always shut off after a 30' of use. The lamp lcd is flashing and I need to turn off/on the unit If I want to use it. I think it had a bug but I don't know if I can made something easily or need a repair by specialist.
Help please.
  • Anonymous Feb 21, 2009
    new bulb $350 reset lamp hours tried all settings, unplugged dynamic iris .tried lowbulb, highbullb.low fan,high fan it restarts every 10 to 15 minutes
  • tlrorick Mar 19, 2009
    same problem. replaced the lamp, unit powers on and then off again. contacted Panasonic Tech Support. they said to take it to a Panasonic repair shop who thought it was the ballast. repaired that, they still cant get it to work. they have contacted Panasonic. during the 3 weeks they have had our unit, another one has come in with the same problem. I contacted Panasonic today and they will contact their repair shop to see if they can help. we will see.
Reseat the lamp.  I had a similar problem.  Replaced the lamp and everything worked for about 3 hours.  Then, turned the projector off.  Next morning, when I turned it on, nothing.  Stanby/On light flashed green for a minute then the lamp light came on and the projector went into standby.
Posted on Feb 07, 2009
  • Keefa Feb 07, 2009
    Yeah, never mind my "solution."  After several power cycles and no problems, just went down to use the projector and no luck.  Standby/On light flashes green for a 30 seconds or so then it's straight to standby with the lamp light flashing.
Unit powers up then shuts off after a few seconds
The problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a powericon1.png supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so, you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Apr 07, 2013 | Sanyo PLC XP30 Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Panasonic projector keeps shutting off
    Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
    http://www.youtube.com/watch?v=6jGwB05_gdk
    May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
    5 minute fix guaranteed
    worked for me
    Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
    Panasonic PT L501u Replacement Lamp
    panasonic projectors , even if the lamp has reached end of life gives u 10 minutes to reset the lamp counter
    so when u replace a new lamp, go to options, lamp counter, reset & press stanby button for confirmation!
    thats all the unit powers off & when u check the lamp counter , its shows 0
    u r done!!!!!!
    Jan 22, 2009 | Panasonic PT L501U Multimedia Projector
    PT-AE 900U LAMP GOES OFF
    does it stay on for about 10 minutes, then shut down? If so, that is indcating the lamp is near end of life, according to an hour counter built into the system.
    The growling is probably the Dynamic Iris which has had a lot of issues. Mine started making noise after about 1 yr 9 months of ownership/use. Since I bought it with an AmEx card which doubles manufacturer warranty, I was able to send AmEx the quote, and they sent me a check, and I got it fixed.
    The cheapest place I found for a replacement lamp is through one of the 2 or 3 sellers on ebay; I bought one last week for $260 delivered. Lamp is very easy to replace, but then follow instructions for resetting the lamp hour counter, or the unit will still think the lamp is near end of life.
    Jul 30, 2008 | Panasonic PT-AE900U Multimedia Projector
    InFocus LP725 light goes out after 10 minutes
    The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
    Check the projector’s lamp to ensure that it is securely connected
    in the lamp module. Make sure by removing it and reinserting it.
    Check the cables for problems.
    When testing, power up in this order. Projector, Computer monitor, Computer.
    A minor power surge may cause the lamp to shut off. Turn the
    projector off, wait at least 30 seconds, then turn it back on.
    I hope these suggestions help
    Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
    INFOCUS Lamp replacement
    you tried holding down both of the volume keys for 10 seconds while powering up?
    Jan 29, 2008 | InFocus X1 Multimedia Projector
    Infocus LP725 projector
    May 25, 2007 | InFocus LP725 and LP735 Replacement...
    Panasonic PT-AE900U Multimedia Projector Logo
    810 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
