Question about Kodak EasyShare CX6445 Digital Camera
Shutter wont open , and the lens wont come out.This is the first time i dropped the camera , we had it for almost 3 years. I am so mad!!
    Genius:
  • 2,985 Answers
Nothing for you to do there- obviously the mechanism is damaged- unfortunately there is not a repair option for a camera this old I would imagine. New camera time.
Posted on Jul 19, 2007
SOURCE:
I dropped my Polaroid i532 and now the lens wont
hi,
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Thanks....
Jul 07, 2010 | Polaroid i532 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
The camera shutter wont open
if the camera is turning on and the lens pops out, it is not fully expanding. this may be because the camera was dropped and now the lens guide is damaged.
Nov 07, 2009 | Nikon Coolpix S550 Digital Camera
Dropped camera now lens shutter won't stay open
Got to take it to the repair agents. I fixed these cameras for 4 years, will probably need a new lens. Sorry.
Sep 23, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
I have the canon sx100 is, it dropped and now the shutter eye won't open
If only the shutter eye is not opening but the lens is extending properly, then you will need to remove the fron shutter frame and review it.
It may be that one (or both) springs that open the lens protector are loose, or the plastic tab that allows to open/close the lens protector is broken.
If the lens does not extend when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jul 18, 2009 | Canon PowerShot SX100 IS Digital Camera
Camera won't turn on
Fixed! Several people I've described the problem to asked me if I dropped the camera, and I honestly did not remember dropping it, but I could've just forgot that it happened. Later, (after this was posted) it slipped out of my hand and fell to the carpeted floor. When I picked it up, I noticed that the lens shutter had moved (to be closer together). I turned it on, and after a few automatic adjustments, the camera was working like normal again! Perhaps the same thing that broke it, fixed it!
Jan 17, 2009 | Olympus Cameras
50mm C lens issue
From your description, Yes. All RB67 lenses have common problems, usually sticky blades. Since there are 2 sets of blades, (shutter and aperture), the shutter blades may be contaminated with oil/debris
Apr 19, 2008 | Mamiya RB67 Pro SD Medium Format Camera
Shutter
Do you really mean the shutter? Or do you mean the lens barrier? The lens barrier opens in front of the lens when you go to take a photo.
Assuming it is the lens barrier which is stuck open, the cause is usually dust/grit. A series of "puffs" with a large bulbed blower, e.g.a Giotto, should help clear it.
If it's been caused by liquid ("coke" is a favourite!) then the sugar is holding it open. A little (very little) ethyl alcohol dropped on the lens and allowed to percolate around the barrier area should sort it.
If it is the shutter you mean, then that is a workshop job.
Apr 05, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
Powershot A80
hello, your camera has problem regarding to lens assy. and to fix the problem your have to repair or replace the lens assy. so it is better to go to Canon shop. good luck..
Jul 23, 2006 | Canon PowerShot A80 Digital Camera
Kodak EasyShare CX6445 Digital Camera Logo
94 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
