Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
Will not complete boot sequeance
When attempting to turn laptop it starts to boot then stops and goes to screen asking if I want to boot in safe mode or start notmally or last known good configuration, I tried all of these and nothing works, keeps returning back to same screen, not sure where to turn, please help When I turn on the laptop, it goes through the motion of starting up then comes to the configuration screen. If I press the f10 key, it brings me to the PhoenixBIOS setup utility. I can't see how I may get the computer restarting properly. I don't have the setup disks to try them.
  • HP Master
  • 2,404 Answers
Can you get into safe mode? If so then do a system restore to the last known date that you know the laptop was booting properly.
Posted on Jan 30, 2009
When i turn my netbook on it goes to the window where it asks you if u want to run in safe mode when i pick any safe mode it loads all the lertters then it goes to the blue screen. then on the bottom of...
This error code means that Windows cannot access the boot device. This is caused by an error in the formatting, or operating system files on your boot drive.
you may need to re install windows in the current partition, or re-format your HDD then do a complete re installation of your OS. If you need help with that, feel free to ask me. :)
Jan 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
When i turn on my laptop it goes to start windows normally or last known good configuration but when i select one it goes right back to start windows normally page again
Insert your OS system disk or recovery disk. reboot computer, boot from DVD, start installation of software, do not repair from the first prompt when asked, click install, once windows searches for previous version of windows click repair. This will reinstall the system folders and straighten out any registry problems. once complete you are done.
Nov 30, 2009 | Acer Aspire One AOA150-1784 Netbook
Can't boot to safe mode
continuesly press F8 key before the OS boot.
then you will see the list of options,
the first option will be the safe mode.
select that option, it will boot the system ito safe mode.
dont forget to vote
Nov 16, 2009 | Acer TravelMate 2423WXCi Laptop
My acer laptop travelmate 2400, stops at the acer dispaly screen?
When asking questions, please let us know what operating system you have, that goes a long way into us helping out....thanks you. You can try to boot into safe mode first, just to see if the laptop will boot into windows period. When the acer screen first appears, tap the F8 key repeatedly until you see a multiboot minu appear, if you di, that is a good first start...now scroll to the "Safe Boot with Networking" and select it. If the laptop boots into safe mode, I suspect something must have been downloaded like a windows update that may not have installed correctly and corrupted the Startup. If you booted into safe mode, send me a message and I'll explain how to restore the system back before you had the problems. If it doesn't boot into safe mode I might be able to help with that too, but I need to know the operating system.
Sep 11, 2009 | Acer TravelMate 2300 Notebook
My hp pavilion zv5320us laptop will not boot up... Once it turns on it asks where do i want to boot from, the boot order or from LAN. If i do not enter anything it goes to a black screens and says : For...
yeah if you have your win vista cd with you boot from the cd and clixk on repair your computer, here use the restore computer and not complete system restore.
Jul 14, 2009 | Computers & Internet
REPAIRING WIN XP FOR A HP 530
If repairing the XP installation is not solving your problem, you can try a clean install by formating your drive and re-installing XP.
Jun 29, 2009 | HP KP497U9 Notebook
Toshiba satellite laptop comes on and stays at windows xp page
If Safe Mode doesnt work then you may have to do a "repair" of your O/S. Place your Windows XP CD into the CD-Rom drive, reboot and once you see the options if you want to Install or Repair - choose Repair. This option will make repair to your O/S and for safe mode.
Once repair is complete do a complete Anti-Virus and Spyware scan of your Hard Drive. If you can boot into Safe Mode to run the ani-virus much better.
Dec 28, 2008 | Toshiba Satellite L35-S2366 Notebook
Several possibilities. 1. Your windows installation is corrupted. You will need to use your recovery CDs or the recovery partition to reinstall windows. 2. Hard drive failure causeing windows corruption. 3. Bad memory. 4. Bad motherboard. Chances are, it is one of the first two. When you first turn on the computer, press repeatedly the F10 key until the laptop boots into recovery mode. It should automatically go to a place where you can do a soft recovery of the hard drive or, that is to say, a non destructive recovery, only removing the windows files and reinstalling the original windows files. This leaves your data intact. After the operation and if it is a success, you may have to reinstall some software programs again if they don't work but your data will remain in tact. If that doesn't work, do it again only when the recovery screen comes up, press the advanced button which will take you to a complete system recovery where it will reformat your hard drive and reinstall your laptop to its factory preset, just like it was the day you bought it. If neither of those work, you need to get a program that will run a scan on your hard drive to check it for errors but, normally, the first solution will do just fine for you.
Jun 22, 2007 | HP Pavilion ze4125 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
