Question about Samsung Cell Phones
Samsung gt 3301i is continuously charging itself
It keeps showing connected to pc without being actually connected otherwise the phone is working well
SOURCE: Samsung SGH-G600 connection to pc studio3
Try this, I had a the same problem as you guys + found this on a web forum. Quite a frustrating problem to have, It fixes the phone, but after a while you have to do this over again. I am wishing I never bought this phone, even though the reviews were really great.
Unplug usb cable from phone
Type *#52828378# into phone
this comes up
1 Trace setting
2 OTA type setting
3 Serial test
4 TFS reset
select 3 serial test
this comes up
1 PPP UP
2 Serial download
3 Run TCK
Select 2 Serial download
Phone will reboot.
Once rebooted, connect usb cable and pc studio will now work.
Posted on Oct 06, 2008
  • 11 Answers
SOURCE: Cannot connect Samsung GT-S5230 tp PC
TRY TO CHECK THE SETTING OF YOUR PHONE REGARDING CONECTIVITY.
Posted on Aug 21, 2009
  • 36 Answers
SOURCE: For connect samsung gt s3310 to pc ,for internet purpose.
go to www.samsungmobile.com then enter your model no.,you shall get the compatible PC suite for your phone
Posted on Sep 20, 2009
  • 324 Answers
SOURCE: can't connect net on pc using Samsung Galaxy spica Gt-I 5700.
for settings you need to contact your service provider
Posted on Mar 02, 2010
solitario82
  • 343 Answers
SOURCE: my samsung GT-S5230 phone memory card is not working
take out the memory put in the computer and format after that turn off the phone and put the memory
Posted on May 16, 2010
Why samsung GT-s583ot kept beeping whencharging
hello Sir,its probably because the phone's battery might be damaged.Just replace the battery and then try it.If that does'nt works then just contact the customer service centre or u might end up bricking your phone.
Aug 17, 2014 | Samsung Cell Phones
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
One lg vu 920 turns off after 5 seconds and the second wont recieve service
  • Keyboard issues (no predictive text):
    • This isn't a "fix" per se, but it seems the best route is to use an alternative keyboard. Swype is pre-installed on the phone, so you can switch to that without installing anything new. Alternatively, you can try other players such as SwiftKey, A.I.type, and TouchPal. Otherwise, LG is aware of the issue and working on a fix.
  • Phone won't charge
    • The potential fix is to enable USB Debugging. To do so, head to Settings -> Applications -> Development -> make sure USB Debugging is checked.
    • Alternatively, if it won't charge normally (while powered on), it should charge while powered off. Your best bet is probably to power it off and let it charge while you sleep.
    • For some people, it seems that the phone actually is charging, it just doesn't show it.
  • Can't use USB storage
Unfortunately, there are no perfect fixes for any of the issues listed above. Other users are reporting a smattering of smaller (and substantially less frequent) issues, but hopefully the above can help some people with the most significant issues.
Mar 02, 2012 | LG Cell Phones
Every time I plug my phone into the computer it says that this driver was not installed properly. The battery charges but I cannot see the phone. Also I would like to use my phone as a modem... please...
That is showing because you have not installed right driver for your mobile. just go this url http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1903&prd_mdl_cd=GT-E2652MSAINU&prd_mdl_name=GT-E2652&srchword=Champ+Duos+E2652 and download new samsung pc studio for your phone after entering phone model after downloading it install NPS in your computer and then connect your phone via USB cable it will work ...
Aug 05, 2011 | Samsung Star GT-S5233 Cell Phone
I got my captivate wet a while back and it was malfunctioning for a while. Its been a couple of months since i actually dealt with it but it seems to be working like normal, except it continues to reset...
You've got a short... I'd see if the contacts for the battery or usb ports have corrosion on them- a little contact cleaner does wonders. Otherwise, the best bet would be to replace the phone- unless you can find the corrosion, it will just continue to reset itself
Jun 07, 2011 | Samsung Captivate Cell Phone
Sumsung GT-C 3530 do not connect with pc pleace give me sumsung pc suite
Download Samsung Kies PC sync software from following Link:
http://downloadcenter.samsung.com/content/SW/201105/20110501111040085/Kies_2.0.0.11044_11_3.exe
If this direct link doesn't work, Go to:
http://www.samsung.com/us/support/downloads/global
Select Category as "Mobile Phone", Sub Category as GSM(2G), and select your model as GT- C3530
It will show list of options. Select the second link and download Samsung Kies software. Then you will be able to connect your phone to pc
May 31, 2011 | Samsung Cell Phones
I bought a Samsung GT-B3410 phone and it did not have the software disc. I have gone to the website to download the PC Suite (software) to my computer and no success. Kindly assist. Regards, Joshua
I used Samsung Corby GT-B3410 for almost 1 year now... From the last few days it keeps restarting while using it... What will i do? It keeps restarting twice or maybe thrice in a minute... Its a big problem for me.. Please help!!
Jan 06, 2011 | Samsung B3410 Cell Phone
I just tried to connect the samsung DUOSBT5722 to pc with windows XP OS. Kies has been installed. The phone continuosly shows "connecting" even after 15 min. and not recognised in Kies programme....
I had this problem. Don't know why it is not detecting it. I just installed Kies on different pc with windows xp it worked since I had spare system at home. It seems there should be some conflicts
Nov 27, 2010 | Samsung B5722 Cell Phone
How can i connect my samsung corby pro phone to wifi?
1. go to "menu"
2. go to "wi-fi"
3. click the central icon (it will activate wifi)
4. click to "search" (it will search available wifi links)
5. click on the desired wifi-link
6. click "connect"
Apr 08, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
