Question about Car Audio & Video
My pioneer car radio with removable face is stuck, can't turn off power
3 Suggested Answers
  • 149 Answers
SOURCE: Remove Pioneer radio from dash
Try ebay:
Item number: 370036329272 rtcurve.gif
If the facia comes off, remove it and you should see two vertical slots. Insert the keys and pull out the unit. Disconnect the plugs for speakers power and ariel.
Posted on Mar 26, 2008
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
On my pioneer p6500 it is stuck on demo mode how do I turn this off so my radio will work
You should still be able to turn the radio on even if it is in demo mode. If you can''t turn the radio on, you have other problems. Did you try pressing the source button? Most pioneer radios tell you how to turn demo mode off when you first put power to it.
Apr 12, 2012 | Pioneer Car Audio & Video
My face plate is frozen. The cd player works but nothing else what could be the problem.
First thing that I would try is to reset the radio. To do this, you would want to press the reset button (located behind the faceplate) using a bent paperclip or a ball-point pen. If this type of reset (soft reset) doesn't work, then you want to disconnect constant power from the radio (hard reset). This can be done by removing the power fuse for the radio or disconnecting the negative terminal of the car battery for about 15 seconds.
Start with those two methods. Beyond that, you may have a bad faceplate and/or a bad unit and it would need to be sent to Pioneer Electronics or an electronics repair technician. For repair estimates, I recommend visiting an authorized Pioneer retailer in your area.
Nov 17, 2011 | Pioneer DEH-P3500 CD Player
XMp3i is stuck on "powering
Bad TSOP flash chip. No way to fix without disassembling, removing the flash chip, and placing a new flash chip on it. Doing so requires a donor radio (with another issue), and will change your XM Radio ID. You'll also need to have a hot air (or IR) rework station for desoldering the old chip, and a soldering iron for placing the new chip on the radio.
I'd say give pioneer a call since it's a design flaw, and a VERY common issue. My best guess is that it's caused by excessive heat & defective chips.
Aug 07, 2011 | Pioneer GEX-INNO1 XM Radio Receiver with...
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-N2 does have unlock code?
no, this radio has no security code... Check to see that you have power on the yelow wire at all times, Power on the red wire when the key is on, and make sure the black wire is grounded well. something could have been disconnected at the paint shop.
Jan 03, 2009 | Pioneer AVIC-N2 Car DVD Player
Power will not turn on
i just sent the radio to pioneer still waiting
Aug 30, 2008 | Pioneer AVH-P6500DVD Car DVD Player
DISC STUCK AND ERROR 02 MESSAGE
hi, i have a kenwood kvt_725(or did have before some scallywag robbed it) i had a simular problem when ejecting discs i found that if you turn power off and removed face plate and turned ignition off it eventually ejected the disc and worked, or a simular routine with the face plate then ignition etc etc. i know it seems a lame solution sorry but hope it helps.....
Mar 20, 2008 | Pioneer AVH-P6500DVD Car DVD Player
Cd pioneer dehp350
check for a stuck button on the face. Thats what happened to mine. Nothing on the face worked... remote wouldn't work...started pushing buttons untill one "popped" and then everything was fine.
Dec 31, 2007 | Pioneer DEH-P3500 CD Player
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
