Polaris Sportsman 90 ATV With No Spark
Wwe have a 2004 Polaris Sportsman that just quit running one day. I discovered it had lost spark so I installed a new plug, but still no spark. Then I placed a screwdriver in the plug connector to see if it would spark against the frame. Again no spark. Could it be the CDI Unit or any other suggestions? Thanks for any help, Chris
  • 2 more comments
  • thomasTurnbu Mar 22, 2009
    I have a 2001 Polaris Sportsman that wouldn't start after riding in water and slush. It lost spark so I installed a new plug, but still no spark. Then I placed a screwdriver in the plug connector to see if it would spark against the frame. Again no spark. Could it be the CDI Unit or the stator ? Tom
  • Anonymous Apr 16, 2009
    I have a 2004 Polaris Sportsman that just quit running one day. I discovered it had lost spark so I installed a new plug, but still no spark. Then I placed a screwdriver in the plug connector to see if it would spark against the frame. Again no spark. Could it be the CDI Unit or the ignition coil any other suggestions? Thanks for any help, david
  • Anonymous May 05, 2009
    i also have a yamaha 95 kodiak 400 with very weak or no spark. i repaced the cdi box and ignition coil and still have a very weak spark. i checked the resistance of the pickup coil and the magneto coil in the stator assembly. the large coil in the stator is shorted to ground. i need to know if this is normal.i dont have a wire diagram to tell if its wired that way or not. thanks
  • krisbom May 24, 2009
    '04 Polaris Sportsman 90 no spark at coil, cdi working, replaced coil asm, cleaned stator noticed that flywheel's magnetic field is not so strong, isnt that the problem?
Sportsman 90 with no spark
Posted on Nov 28, 2009
I have a yamaha kodiak 400 had the same problem ran fine then just died no spark it was the small pick coil in the stator. now i ahve spark but only when i first turn the starter over then nothing im still trying to get mine running ... but i would check the pick up coil you can un plug the harness coming out the crank case and check with Ohms meter good luck
Posted on Apr 24, 2009
Hey um try to start with the choke on mine died on the road and it needed choke i just got it home,
but you cant let off the gas ill post more when i see if it starts again
Posted on Jun 13, 2009
Yamaha atv repair manual
i have one touch 3g modem and i want to unlock it any one can help me plz
the imei code : 867612003589540
Nov 27, 2013 | Computers & Internet
What is the current trends in the space robotics and space rovers?
The twin rovers Spirit and Opportunity are the latest in lunar rover equipment. They have exceeded their planned life by 90%! That is huge, they should have been dead after only 90 days not years.The same technology that the rovers use to drive themselves on Mars is the technology that was being tested on the DARPA grand challenge in the desert with the robot car race. Currently we operate the space rovers by telling them where they need to go and letting them run, due to the distance it could take 4 hours to directly command the rovers.
www.onlinerobotics.com
Jan 08, 2013 | Computers & Internet
Insatlled Sierra 597 on Vista, lost keyboard & mouse etc.
Try a system restore to a previous date when the computer was working fine. Please backup all your current DATA as you may lose them.
Good Luck!
Sep 02, 2009 | Computers & Internet
CREATIVE LAB BLASTER V .90
I BOUGHT A NEW LAPTOP ITS FRM DELL I INSTALED XP OS BUT ITS MODEM DRIVER NOT GET THE MODEM DRIVER NAME CONEXANT CX20561
Dec 20, 2008 | Creative Labs Blaster V.90 Modem
Atv free repair manual
were do i find a wiring layout for my atv(brute force
Oct 21, 2008 | Computers & Internet
Modem driver
All of you who wanted DLink DFM 562-E's driver, please click the mentioned below:
DLink DFM 562-E (XP)
D Link DFM 562E (Vista)
Thank You
Sep 09, 2008 | D-Link DFM 562E (dfm-562e) Modem
Modem Problem?
In order to really test your modem you need to call more than just 1 (your ISP's) number. If you are not getting 56k connects, you should try your modem with other local/toll/toll-free numbers. This is a list of some toll-free numbers, the 3Com "Line Test" Number (a toll-call), and links to various ISP local access number listings Setting up an account with a Free ISP is another way you can test and isolate modem/ISP problems.
1-847-330-2780 - USR Linetest number - this is a toll call; if you log-in as "Line Test" with a v.34 modem, it will attempt to determine if your line will support 56k connections.
1-847-330-4569 - US Robotics' V.92 Test number - this is a toll call; the server is a 3Com Total Control HiPer ARC running V.92 server side code that supports PCM upstream.
The following numbers use toll circuits but are free to the caller (as long as you don't log in):
1-800-245-3828 - (Canadian weather BBS)
1-800-590-4857 - (IBM Global network access # x2 and V.90 3Com Server)
1-800-784-3638 - (Netcom - supports V.90)
1-888-861-8490 - (MCI/Worldcom))
1-888-245-0113 - (AOL access x2)
1-800-716-0023 - (AOL alternate access)
1-888-296-3892 - (AT&T Worldnet accessV.90,x2)
1-800-638-1483 - (GTE Net access - V.90/K56Flex Ascend Server)
1-800-572-1959 - (Compuserve V.90,x2)
1-800-350-6885 - (Earthlink - V.90,x2)
1-800-853-7921 - (Earthlink - Flex)
1-800-534-7097 - (Earthlink - Flex)
1-800-304-4226 - (Shore.net - Flex)
1-800-320-4509 - (Ascend 56KFlex test line)
1-800-779-2966 - (Used to be MCI)
1-800-846-7562 - (Gateway BBS)
Apr 03, 2008 | Agere (DSLU56KPCI) Modem
How to switch on?
Dont be so upset.
You dont know the theory of your PC screenPowersupply so it happened.
With regards
Jan 07, 2008 | Dell - Card, PCMCIA, Modem, 56K, V.90...
Computers & Internet Logo
4,634 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
