Question about Bose V25 Theater System
Bose flickering Audio works fine, television keeps flickering on every input.
3 Suggested Answers
  • 16 Answers
SOURCE: No audio with CD/DVD but works fine with aux and FM
Check the cable between the media centre and bass module for signs of damage (if its buried in the wall / under the floor and you can't check it, assume it could be damaged).
however, this sounds like a fault with the Digital Analogue Converter - this coverts the digital audio on a disc to analogue information the amplifer can use to produce sound. Contact your retailer for exchange / repair.....
Posted on Jan 16, 2008
  • 71 Answers
SOURCE: how to get video/audio input from Xbox 360 & digital cable input
Hook them all to the tv and with audio out from the tv run that to the bose 321.
Posted on Mar 15, 2009
My Bose lifestyle DVDs player no color only black and white!
What series is your Bose Lifestyle System?First,check if the composite video output from your Bose Media Center is connected to the composite video input of your television.It will only show black and white if it is connected to the component video input of your television.
May 25, 2017 | Bose Audio Players & Recorders
I have a Bose Cinemate II and an NTSC/PAL AVOL television. I am in Germany. I want to connect the audio, but the TV only has a VGA slot, and I can't figure out how to get them together.
tv model number? does the tv has Audio Out. from tv out to bose input. could be optical or rca type whichever is available.
i think you can use the headphone out but you might need an adapter plug (male, sized to fit) then splits into two male rca plugs (left & right) which will be plug into the bose audio inputs.
if the bose has coax input (digital), better use this.
Oct 07, 2015 | Televison & Video
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
I would like to hook up an HD tuner to my Bose Wave Radio through the RCA input jacks . . . . I've done this with an iPod and it worked . . . . will the tuner play through the Wave Radio?
Of course it will if it has audio outputs. For all the Bose knows it's just a standard external audio device. What keeps you from just trying it?
Jun 26, 2011 | Bose Wave Radio
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
How do I use my Bose Subwoofer with a different receiver??
You can use Bose Sub woofer with any receiver. There is a set of "Audio Input" jacks on the back of the Bose. Connect the plugs on the one end of the audio cables to the "Audio Input" jacks on the back of the Bose.
Connect the plugs on the other end of the audio cable to an "Audio Out" jack on the receiver.
If the "Audio Out" jacks do not match with the plugs of the audio cable, then you need to use adapter or modify the audio cable.
In case "Audio Out" jacks are not provided on the receiver, you may take the audio output from headphone socket.
hope this will help you.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Bose Lifestyle 28 System
I an lg47 240 hz flat screen hooked to a bose 3-2-1. I got the dvd to play through the bose and sound working through both the bose speakers and tv speakers, but when I try to get the tv to play through...
if you are using a hd reciever make sure the audio output goes directly to the bose system... if you do not have an hd reciever make sure its audio out on the television that you are using if you do have it hooked up right make sure the bose 321 is on the right input such as audio in!!!
if it still is not working exchange it.
Nov 18, 2009 | LG 47LG60 LCD TV
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Jan 12, 2008 | Bose 3·2·1 II System
Bose V25 Theater System Logo
46 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
