Question about Air Tools & Compressors
Turns on but only fills to 10 psi and then does not fill more
Turn on, starts and sounds normal till 10 psi then go to a lower toned pump nois and wont fill past 10 psi on the tank gauge. i dont hear anything else when i turn off. seems to lose the 10 psi slowly.
can i fix it my self. the thing is only 2 years old and has only been used a few hours.
  • clearblome Jan 27, 2009
    it is a coleman brand, inflation mate odel,1.5 gallon, electric air compressor. it has an adjustment but only for out flowing pressure. it has 2 gauges, one for tank and one for outflow psi i think.
  • Carlton Lowry May 11, 2010
    What brand is it? Is it oil fill, or oil free? Electric, or gas powered? Does it have an adjustment dial that you can turn up tank storage pressure?
  • 1,388 Answers
There is a one way checkvalve installed on the tank that prevents air from returning to the pump. Follow the discharge hose from the pump to the tank. You will see a brass valve that has a 1/4 inch hose attached that leads to the pressure switch where you will find the unloader valve. Check if the unloader valve is leaking and continues to leak when you turn off the pump. If the valve at the pressure switch is leaking ~ then the check valve at the tank is the source of the leak and needs to be cleaned to replaced. Some low volume compressors will never fill if the tank check valve is bad. Check this first and email me for more information. Good Luck
Posted on Jan 27, 2009
Have 2005 chevy Silverado and its overheating have changed the water pump and thermostat have new hoses what else could be the problem
I would run radiator cleaner thru truck several times till water is clear and fill with correct ratio of antifreeze/water. Check oil if milky you have a cracked head or head gasket . clutch fan may not be engaging radiator old or incorrect for truck Semper Fi!
Feb 05, 2015 | 2005 Chevrolet Silverado
Fills, goes 4 minutes and fills, pauses, then fills, pauses then fills, over and over
Sounds like its syphoning out the water. If it was overfilling, you would have water everywhere, the machine would eventually flood. Check the drain hose. Make sure the end is higher than the water level in the machine and that there are no extensions running outside which have an end lower than the water level in the machine, it will start syphoning, usually after the first pump out.
Jan 01, 2015 | Washing Machines
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
My 2002 jeep grand cherokee limited made some thumping noise followed by boiling sound then a "pppsssstttt" with steam The theromstat reading was in the middle and check gauge light illuminated....
The first place to look regarding a problem like yours is the thermostat. Replace it, refill the system (it's OK to do the work without draining but you will need to replace whatever you lost doing the work).
When re-filling, turn the heater on high, fill 'till it doesn't take any more coolant, turn the engine off exactly when the engine reaches normal operating temp, wait about five minutes, re-start and continue filling till full.
Monitor everything for the first day. Any overheating, leaks,white smoke from the tailpipe, oil in the cooling system or coolant in the engine oil indicates you have a larger problem that requires further diagnosis. if all is OK you are done!!!
Any questions, just ask.
Feb 23, 2011 | 2002 Jeep Grand Cherokee
Cranks normal wont start
bad spyder it sonds like
Apr 01, 2010 | 2000 Chevrolet Blazer
2004 pontiac grand am no start
if your fuel filter is plugged this will happen, but you may have a bad fuel pump,if you can a tester is about 20 dollars and there is a port to screw it on on the fuel rail at cranking you should have 50 to 59psi after start up you should have 3 to 6 psi lower, but just to test the security, turn key on for 10 minutes then shut off count to 5 and try to start it
Mar 15, 2010 | 2004 Pontiac Grand Am
Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Oct 10, 2009 | 1994 Dodge Ram
Shut off,wont start has fuel psi on filter, no code an fuses good
sounds like high pressure oil system problem if there is an internal leak the fuel injectors will not fire. with a scantool you should moniter cranking rpm,and IPC (injector pressure control) should be at a min of 500 psi your.
Jun 16, 2009 | 2005 Ford F 350 Super Duty
98 s-10 2.2 Fuel Pump Pressure
40 psi good lower than that bad
Apr 21, 2009 | 1998 Chevrolet S-10 Pickup
Air Tools & Compressors Logo
227 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
