Question about Tappan TGF363 Gas Kitchen Range
Timer on tappen stove won't stop buzzing - Tappan TGF363 Gas Kitchen Range
I would like a manual for this stove please
you did not give a name and model number of the stove, the only suggestion I can give is to type in the name and mode number of the stove---example-tappen--567 manual in your search engine and see what comes up
Mar 22, 2016 | Kitchen Ranges
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Wanting to change gas stove to propane
yes. the ports are different diameters. try www.partsselect.com
Aug 20, 2009 | Kitchen Ranges
My viking refrigerator freezer won t freeze
A lot of problems have been reported with this model,with the defrost timer not moving,Like a clock stopping,the defrost timer has stopped,and won`t allow the compressor to freeze the freezer unit.Most likely not to cool in the refrigerator either is it?If I can help anymore,let me know,but have the defrost timer checked or replaced.
Jun 12, 2009 | Viking 42 in Built In Professional...
TIMER IS BUZZING NON STOP.
how old is the oven? does it have a analog clock? If it does then turn the stop time clock and the buzzing should stop.
Oct 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
Apr 13, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
