Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
VDSC365-6B Started self clean cycle on oven - turned it off about an hour into the cycle and hae not been able to get the oven door to unlock since then. We have re-set circuit breaker
  • 3 more comments
  • Anonymous Nov 11, 2007
    Self Cleaned oven now oven door will not unlock oven will not work and range is also not working
  • levasheff Dec 02, 2007
    Also Self Cleaned oven now oven door will not unlock oven will not work and range is also not working
  • Anonymous Dec 21, 2007
    cleaned oven and door won't unlock
  • pat2008 Jan 01, 2008
    I tried to Self Clean --- cycle never started (no heat), but oven door locked and will not unlock now. The oven does work, (except for Self Clean), but is useless since I can't open the door. Have tried cutting power at the circuit breaker, but no luck.
  • wdyck189 Apr 12, 2009
    opened oven door half way into clean cycle
Ove corse you need to make sure your oven is or has cooled down and turn the breaker off for good measure  I had this problem.  I think the locking unit is jumping gears because i hear a grinding sound when Mine locks.  The way I got mine open was,  Lookalong the top of the oven door.  there are vent slits cut in the top, if you look in them where the latch is you will see the hook that is holding the door shut.  I took a butterknife ( you need something flat and strong because of the angle yu have to hold it at.  take the knife and push the hook to the left.  I will take a few tries but it should pop open.  once it is open and power is restored the latch will retract to its normal position.  hope this helps
Posted on Feb 16, 2008
SOURCE:
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
    Hello.
    Please apply the solution this way!
    To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
    • Program the oven to self-clean.
    • Wait 20 seconds.
    • Cancel self-clean.
    • Wait 20 seconds.
    To self-clean your wall oven, follow these simple steps:
    • Remove the oven racks.
    • Set your oven control to "Clean."
    • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
    • Select "Start." (To set a delayed start, see your Use & Care Guide.)
    Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
    Thanks for using fixya.
    Sep 07, 2011 | Dacor Ovens
    How to use self clean for oven
    Turn off the oven light and remove all pans and racks from the oven. Clean the oven and door frames with a non-abrasive cleaner. Do not clean the door gasket. Remove any excess grease or debris from the oven bottom.
    Close the door and move the lock lever to the right. The "Lock" indicator will light. Press the "Clean" pad, then press the up or down arrows on the "Set" pad to adjust the cleaning time: two hours for light soil, three hours for medium soil and four hours for heavy soil.
    Cancel self-cleaning after it has started by pressing "Cancel."
    Wait one hour after the cleaning cycle has ended for the "Lock" indicator to go out. Unlock the door.
    Clean the oven racks with soapy water and a scouring pad and put them back in the oven.
    Sep 25, 2010 | Maytag MGR5752BD Gas Range
    Started to self-clean, locked the door, etc. Had
    Hi.
    The appliance door is probably locked in consequence of the self cleaning cycle.
    Unplug power cord, and allow the oven cooling down for few hours.
    If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
    Parts must be tested to discover the fault.
    Call Frigidaire at the number listed on the owners manual.
    Regards.
    Mar 03, 2010 | GE Ovens
    Oven door is locked and will not clear. I have tried to reset. Turned the breaker off, The only button that works is the timer. I am not cleaning the oven it was locked by accidentially leaning against the...
    Hello JJ, Try pressing the "Clear/OFF" button to stop the self cleaning cycle. It will take up to an hour before the oven will unlock the door, if the oven has started to heat up for the cleaning process
    You may have started the default 3 hour self-clean cycle, so you can attempt to reduce the time to 2 hours, by pushing the timer down so it displays "2" which would indicate the shorter cleaning cycle. Then at the end of the timed cleaning cycle, it should open up, once the temperature has cooled sufficiently for it to be safe to open, again, which takes up to an hour to sufficiently cool.
    Typically, when an oven is accidently put into self clean mode, the timer "kicks in" and the timer has to run out before the oven will unlock. With the older mechanical knob timers, you could just rotater the timer until you reached the end of the pre-set time. With the electronic timers, you have to let the timer "count down" until it reaches zero before the oven will unlock the oven door.
    Here's a link to the Frigidare site where you can select your specific FEF352 version and download a owners manual, free of charge.
    http://www.frigidaire.com/manuals
    Just enter in FEF352 and then scroll down the page until you find your particular version of teh FEF352 oven/range and then click on "complete owners guide" (english) to get the manual in an Adobe pdf format.
    I hope you find this Very Helpful and best regards!
    Nov 23, 2009 | Frigidaire FEF352 Electric Kitchen Range
    Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
    I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
    Seems OK now.
    Oct 15, 2009 | Ovens
    Jenn-Air stove locked
    After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
    Dec 10, 2008 | Ovens
    Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
    286 people viewed this question
    Top Viking Kitchen Ranges Experts
    wrtsjr
    Level 1 Expert
    Ismael Rodriguez...
    Steve Allison
    Steve Allison
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
