Question about Norelco Health & Beauty
Norelco 875rx shaver charging
How do you know when the batteries are charged on a 875rx norelco shaver
ButtFuzz
  • 463 Answers
SOURCE: old norelco 3605x electric shaver doesn't charge, doesn't run etc
Batteries are toast.
Posted on Mar 26, 2009
SOURCE: My 985RX Norelco shaver will charge up to 50
charge your shaver  for 4hours again it will solve your problem
Posted on Oct 05, 2009
freetek
  • 5568 Answers
SOURCE: Norelco shaver 6866XL won't charge, light glowsred
The battery is probably one with multiple cells and one (or more) of them has shorted preventing the total from reaching a voltage that appears as fully charged.
If the cells are Ni-Cads, this is a common problem with them and when a battery-operated item of mine fails, I replace those older types with NiMH cells if the battery compartment can accept them.
I have 'restored' countless NiCads over the years by 'zapping' them with a fairly high current for a second or two; voltage isn't important as long as it is in excess of 2-3 volts but the source should have a few amps capacity.
This type of cell grows 'whiskers' that will cause them to short completely or develop a path that causes them to self-discharge faster than normal.
Posted on Oct 16, 2009
cvstan
  • 40 Answers
SOURCE: Shaver was running slow and then died. Replaced
Your original symptoms sure sound like dying batteries. Brushes can wear out. Check if it runs better if you change the orientation of the shaver. Does holding it upside down make it work better or worse? If the speed changes, its probably the brushes. You can buy new brushes, but the Norelco repair place will probably give you a hard time since they want to repair it for you so you have to insist. I have made brushes for the shaver by filing down brushes from some other motor, but this is messy and doesn't always work.
Posted on Jan 23, 2010
brector3
  • 1600 Answers
SOURCE: I have a Norelco 5822 XL cordless electric shaver.
If the old batteries were corroded, that may have damaged the circuit board. If the batteries were getting hot before the shaver died, the heat may also have damaged the circuit board. It is also very possible that the salesperson did not do a good job installing them as they are not trained in replacing batteries in shavers.
For expert shaver battery installation, you can contact shaveroutlet.com
Posted on May 08, 2010
Is HQ9 compatiable with HQ55?
No, philips norelco HQ56 replacement heads compatiable with HQ55
philips norelco HQ56 for norelco 100db, 110db, 1323, 2005c, 200sc, 300sx, 3405lc, 3601x, 3604x, 3605x, 3801xl, 3805xl, 3865xl, 400dx, 410db, 4401lc, 4402lc, 4403lc, 4404lc, 4406lc, 4413lc, 4414lc, 4417lc, 4601x, 4602x, 4603x, 4604x, 4605x, 4606x, 4607x, 4608x, 4625,x 4805xl, 4807xl, 4816xl, 4816xld, 4817xl, 4817xld, 4821xl, 4825xl, 4825xld, 482xl, 4845xl, 484xl, 4852xl, 4853xl, 4861xl, 4865xl, 486xl, 4885xl, 500rl, 501rl, 505rl, 5426lc, 5625x, 5812xl, 600rx, 605rx, 6423lc, 6424lc, 6613x, 6614x, 6615x, 6616x, 6617x, 6618x, 665rx, 6843xl, 6844xl, 6853xl, 6854xl, 6856l, 6856xl, 6863xl, 6940lc, 6945xl, 700rl, 705rl, 710rl, 715rl, 720rl, 725rl, 750rl, 800rx, 805rx, 815rx, 825rx, 835rx, 850rx, 875rx, 885rx, 885rxac, 895rx, 900rx, 905rx, 915rx, 935rx, 945rx, 950rx, 955rx, 965rx, 968rx, 975rx, 985rx, hp1318, hp1319, hp1327, hp1327d, hp1328, hp1328e, hp1328s, hp1337, hp1337c, hp1601, hp1602, hp1604, hp1605, hp1606 and hp1608.
Feb 02, 2013 | Norelco 3405 LC Electric Shaver
I have Norelco 6867XL. After fully charged, my razor will lose all power one day after. I don't know what happens. Can you help me resolve that problem. Thank you.
the battery of your Norelco 6867XL is weak and cannot hold charge for long any longer. The cell in the battery as become very weak such that it cannot hold charge for a very long time anymore. This it why it looses power one day after it is fully charged.
Have the battery replaced and problem should be solved.
I hope you understand the above, if you don't please let me know for further assistance.
Regards.
Aug 11, 2011 | Norelco Quadra 6867 XL Electric Shaver
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is...
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Jun 07, 2011 | Norelco 3605 X Electric Shaver
Will not hold a charge. model 7617x norelco
According to your problem, you have to change the battery with a new. After several times of charging and uses charging battery also get dry. Then the battery can't hold charge. Only you have to switch a new cell.
May 13, 2011 | Norelco Quadra 7617X Electric Shaver
Norelco 8894XL is charging to over 100 minutes. According to manual, it supposed to charge only to 100 minuyes. What is causing it overcharge?
I have owned a Norelco 8894xl for over 10 years. My battery meter will show 127 minutes after the razor is fully charged. The battery is not over charged. This is normal and does not indicate a problem. Hope this helps.
Jan 07, 2011 | Norelco 8894 XL Electric Shaver
I have a n=Norelco 7160XL Smart Touch that won't take a charge do I need a new battery???
If the shaver no longer holds a charge as it should, you will need to replace the battery. You will find a compatible replacement battery for model 7160XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Dec 03, 2010 | Norelco SmartTouch 9170XLCC Electric...
My Norelco 5615x doesn't hold a charge. Can I
To open the shaver you first need to remove the lotion compartment cover on the back. Then remove the screws to take off the back cover and access the inside of the shaver.
You will find replacement batteries for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Jul 15, 2010 | Norelco Advantage 5615 X Electric Shaver
Health & Beauty Logo
163 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
