Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Printer I have a kodak printer 3aio it says its spooling when it prints. What does that mean by spolling.
  • tammymcamis2 Jan 27, 2009
    Do I need to fix the spooling on my kodak 3aio
    Scholar:
  • 51 Answers
Print Spooler Definiton: "Software that manages sending jobs to the printer. When an application prints a document, the formatted output is stored on disk, and the print spooler feeds the print images to the printer in the background at slower printing speeds."
  • "Storing the print jobs on disk allows multiple printing requests to be queued while the user continues printing from the same or other application without waiting for the current document to be printed."
Spooling: stands for (Simultaneous Peripheral Operations OnLine) S.P.O.OL.
So when it's Says "Spooling", it's basically storing the print job/task on the disk.
Posted on Jan 27, 2009
  • 142 Answers
Spooling, is where the information being sent to the printer is being checked/converted for the printer driver , prior to being printed
  • shyspeed Jan 27, 2009
    no, if the printer is working ok. leave it. i just increased the spooling size file on one of my printers as i was printing large documents. this was done thru windows, cheers!
I am trying to print and keep getting a spooling message
I had the same problem and basically you need to uninstall the driver, then reinstall it again. By the way, Kodak no longer makes printers because they keep breaking due to performance problems. I had two of them and had to return the original four times to Kodak for repair.
If you cannot fix the problem, look into a new printer.
Dec 10, 2013 | Kodak ESP 2170 All-In-One InkJet Printer
PRINTER IS NOT SPOOLING
follow these steps:
1. Click "Start"
2. Select "Printers and Faxes"
3. Right-click your printer
4. Select "Properties"
5. Click "Advanced" Tab
6. Select "Spool print documents so program finishes faster"
Jun 15, 2011 | Kodak Office Equipment & Supplies
Working offline. Printer will not print from word or excel.
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
OR:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it's set to print online
Feb 07, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I got a kodak esp-3aio.what thus it mean when the colored ink indicator keep flashing and the printer totally do not work.
printer will not work if there is red flashing light on it.
Both the cartridges should be filled in order to print or scan
Feb 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
When I tell it to PRINT, it keeps saying please waiton the top of the print preview. Then it will spool or whatever it is doing... I have a Easyshare 5100 all in one. I have new cartridges so that is not...
there is a problem with print spooling options of ur computer call kodak @ 1800 421 6699 they will be easily abl to solve the issue. there are spooling services which are to be restarted.u cannot fix this problem.
Jul 18, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My printer will not print the word spooling keep coming up, I have a Kodak 5500Ai0 printer all in one
Remove the catrage after clean the printer inside.i mean paper peceses.and insert the catraage.
Jul 08, 2009 | Kodak 5500 ALL-IN-ONE PRINTER
Kodak aio3 - stuck on 'spooling' using GIMP
First of all, GIMP uses its own printer drivers (you can view the make and model options under the "Setup Printer" choice in GIMP's Print interface). If your main printer driver choice is not found in GIMP's printer options, you won't be able to print in GIMP. Secondly, for GIMP assings a "Post Script 2" level to the printer by default. If you leave it there, it won't print. You have to change that by actually choose you printer make and model from the drop down box and the save the settings or it will revert back to Post Script 2 on the next load. Hope this helps.
Mar 17, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Restart print spool
Easiest solution is to power off the printer and unplug the printer power cable, plug in the printer and power on then reboot the computer.
Jan 25, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
New Kodak EasyShare 5100 will not print!
You might have to reformat your hard drive as there is something in your OS that is hindering the printing.
Feb 01, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
1,110 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
