Question about Canon PIXMA MG2120 - Multifunction printer / copier / - 5288B019
Canon Pixma MG2120 Error Code p2 - Canon PIXMA MG2120 - Multifunction printer / copier / - 5288B019
bschilz
  • 2049 Answers
SOURCE: what is error code p2
According to Canon, there is no erro P2. They have an E2 or 2 which is a paper out or page not feeding error. Solution: Reload paper in the Rear Tray and then push black and white or color button. Go here for full operating manual...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=17161
Posted on Aug 06, 2009
trisha8765
  • 120 Answers
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
Posted on Dec 27, 2009
Geekman
  • 32281 Answers
SOURCE: Just bought a CANON PIXMA MG2120 printer and the setup CD-ROM will not load. Why?
The CD maybe damaged or faulty.
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Aug 26, 2012
  • 5382 Answers
SOURCE: My Canon PIXMA MG2120 stop printig last night, Gave me an error message 5100.
When the 5100 error happens, there are a few things you can check. The error means that the ink carriage isn't moving across the printer properly. First check if any ink cartridges are not properly seated. (Open the front cover and the paper output tray and then the paper output cover of the printer while it is on. The head cover should open when the cartridge carrier moves into the Fine cartridge replacement position. Then you can double check the cartridges.) Close the covers and check if the problem has been resolved.
If the cartridge carrier doesn't move to the replacement position or the cartridges are not the problem, then you need to check for a jam (paper or other object) blocking cartridge carrier. (Possibly the block is between the cartridge carrier and the "home" position for the carrier.) Turn off the printer and unplug it from the outlet. Open the paper output cover. Avoid the clear film but check for any paper or foreign objects. Move the cartridge carrier to the different sides of the printer to make sure that nothing is under the carrier. Pull any paper slowly and steadily to minimize tearing the paper. You'll have to remove all the small pieces, if they are present. (Note: some paper might have ink on it and thus harder to see. Use a flashlight to help check the corners of the printer.) Check the paper input area as well. After clearing the jam, close the paper output cover, replace the paper in the input tray and check the printer again.
If this doesn't resolve the problem, try resetting the printer. Turn off the printer. Disconnect the data cable if you use the USB cable. (I like to disconnect the cable from both the printer and the computer.) Unplug the power cord for at least 10 minutes (from the outlet and printer, if possible). Reconnect the power cord and data cable. Turn the printer on and check for any error messages.
The next possible problem is a dirty encoder strip. Turn off and unplug the printer. Open the paper output cover and locate the plastic strip. If there are any smears on the strip, use a neutral pH detergent (2-3 drops) in a 1/4 cup of water. Moisten a cotton swab in the detergent solution and squeeze a bit to remove the excess water. (You don't want to drip the water inside the printer.) Wipe the swab across the encoder strip. Use multiple swabs to clean the entire strip. Do not touch the metal rail or push the encoder strip. Check that the encoder strip isn't dislocated from the springs on the ends of the strip. Take another set of cotton swabs, moistened only with water, to remove any detergent residue from the strip. Dry the strip with additional (dry) swabs. Let the printer dry before closing the paper output cover. Then plug in the printer and turn it on.
If this doesn't solve the problem, the printer needs to be serviced. If it is under warranty, contact Canon. Otherwise, decide if it is worth the costs for service. (You have to get the printer to the service center and then pay for the initial evaluation; the evaluation charge will be applied to the repair if you decide to have the unit serviced.)
Full descriptions and pictures of the steps to resolve a 5100 error are available from Canon support: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mg2120?CMD=MIXED_SEARCH&mName=PIXMA+MG2120&mType=PIXMA+MG&pageKeyCode=ekbresults&searchString=5100+error&BASIC_SEARCH_CURRENT_TOPIC_ID=2259&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false .
I hope this helps.
Posted on Jul 16, 2013
SOURCE: canon pixma mg2120 error code e3
Yes
Posted on Sep 11, 2013
What does canon e30 error code mean?
Hi
The code meaning is below
E30: The size of the original cannot be correctly detected or the document is too small when the Fit-to-Page copying is selected
Cliff Cook
MCP
Aug 02, 2014 | Canon PIXMA MG2120 Inkjet Photo All-In-One
Error 2,156,50 canon mg 2120
because I can not always quick scan shows me the error 2156.50
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Canon Pixma MG2120 Error Code E05
If your printer was not in use and out of ink for a long while, the nozzle that feeds the ink through maybe blocked, also check your leaflet of your product (trouble shooting it may give you some idea) if
not.. contact the company where your product was manufactured for more information. hope these tips help!
Jul 29, 2012 | Canon PIXMA MG2120 - Multifunction ...
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Canon PIXMA MG2120 - Multifunction  printer / copier / - 5288B019 Logo
239 people viewed this question
old marine
old marine
