Question about Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive
Can i put a toshiba external on a dell laptop?
I have an external toshiba hard drive and i want to make sure it works, can I set it up on my dell?
  • Toshiba Master
  • 6,487 Answers
Yes you can set it up with a dell computer, there's no problem with that they are interoperable to any brand of computer...
Posted on Jan 27, 2009
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
I have two dead (power supply) PC laptops that I would like to recover some music and pictures from. What is the most economical way to do this now that I have a macbook pro?
When you put the hard drives into an USB hard drive adapter case you cannot boot up the laptops using the external USB hard drive unless the laptop's BIOS has the option to allow the USB device as a boot device.
You can plug the external USB hard drive into any PC/laptop to copy files from the USB hard drive to the PC/laptop.
The MAC cannot read or write to the external USB hard drive unless the hard drive had been formatted in FAT32. There is no way a MAC can read a NTFS formatted hard drive and it will want to format the hard drive.
Oct 05, 2012 | Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Toshiba external hard drive 640Gb appears on my laptop the USB connects perfectly ,it opens but doesn't take in any file .
hello, i would advice you to format your external hard drive by write clicking on it and click on format and click on start to begin, if this does not allow you to still put files on your external hard drive,then insert it on a friend laptop and see whether you can move files to it. I hope this helps. Regards
Feb 08, 2011 | Toshiba 640GB USB 20 Portable External...
Hai this is arun, I got toshiba satellite laptop,the problem is i started my machine,i'm getting error like "no bootable device is found",so i checked in bios,the hdd is not detected,so what to...
This probably means that your HD has crashed. It's more than possible that you will have to replace the HD, which I advise you to do via a registered computers lab. If you still have a warranty for this laptop, I advise you to use it. This may cost a decent sum...
Nov 23, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I need to install a new hard drive .. how do I do
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
Thanks.
May 04, 2010 | Toshiba Satellite A105-S4334 Notebook
External disk is not been detected
Check the BIOS setting, make sure the hard disk is set to Auto (detect) or change the settings to default settings (your BOS may not have this option) then save and reboot laptop.
If the hard disk has not been detected and/or Unable to find the operating system, it means you may have a faulty hard disk or a faulty hard disk controller or the hard disk may not be making proper electrical connection.
To reseat the hard drive, remove the hard drive and reinsert it into the laptop a few times and see if it boots up..
If it still does not see the hard drive then the fault is probably the hard disk. To test if the hard disk is faulty, remove the hard disk and insert it into a hard drive USB adapter and connect it into the USB port of a working computer. If you don't see this drive as an external drive then you will know its faulty. Then you will need to purchase a hard drive, insert it into your laptop then install the Windows operating system and all your device drivers and programs to get your laptop operational again.
If the hard drive is OK the the fault is with the disk controller, and it is near impossible/expensive to repair the motherboard. Put your money towards a new laptop and put the hard disk into a USB hard disk adapter case and use it as as a portable external hard drive.
Best of luck.
Dec 12, 2008 | Toshiba Satellite M45-S351 Notebook
Toshiba external Hard drive not working
I suggest to connect the harddrive straight to the computer as a slave disk, coz i think the casing power has been damaged. make sure u set its jumper as slave, the harddrive in the machine which contaoins windows should be the master.
Mar 11, 2008 | Computers & Internet
Toshiba 200GB USB 2.0 Portable External 200 GB Hard Drive Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
