Question about GE 32GT740 32" TV
Ge 32gt740 at first the tv used to hit the power button and hear a click but then shut off but now just plugging it in now makes a squealing noise.
  • 398 Answers
The GE (actually RCA) 32GT740 uses the CTC203 series chassis. The most common problem in that chassis is a coil connected to the base of the horizontal output transistor comes loose, and the set may run sometimes and then it will shut off by itself. If you keep trying to run the set with the solder joints cracked on that coil then the horizontal output transistor will short out and the power supply will squeel when plugged in. Do not plug the set in if it squeels as this could eventually cause major problems in the power supply. The set needs a new horizontal output transistor and a good resoldering of the drive coil, drive transformer and all related parts. If you do not have experience in unsoldering and soldering electronic components in TV's then have a qualified tech handle it for you.
Posted on Jul 19, 2007
SOURCE:
GE 32GT740 32" TV 32GT740
It souds like a bad power supply and yes it is preferable to have it checked by a proffessionnal tech. I could be wrong !
Sep 15, 2011 | Televison & Video
TV cycles on and off
It has a power supply overload. Don't plug it in anymore or more damage. Get repaired by shop.
Apr 19, 2010 | GE 32GT740 32" TV
32GT740 on pwr up clicks three times then shuts down
Most likely you have a bad flyback transformer. These were famous for this. Transformer is getting hard to find. This is a high voltage circuit. Have a shop check it for you. Thanks for using fixya.
Mar 02, 2010 | GE 32GT740 32" TV
32 in ge tv doesn't turn on
It ur high voltage is dead.Ur FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to ur CRT(tv tube).That must be replace.
Sep 24, 2009 | GE 32GT740 32" TV
It makes the clicking sound to click on but then clicks off.
its going into what the call shut down okay call tv shop they will fix your issue okay good luck
May 06, 2009 | GE 32GT740 32" TV
GE 32GT740 wont turn on
odds are high volt  circuit gave up. 100 150 repair 5yrs not worth repair.
Nov 22, 2008 | GE 32GT740 32" TV
Why is my tv doing this?
Power supply problem. Usually caused by incorrect or missing feedback voltage...accordianman
Jan 16, 2008 | GE 32GT740 32" TV
Help
Hi there!
May be a power supply fault, Line stage, loose solder points or regulation( 5V to the CPU) to trigger switch on. If not familiar with electronics, please refer to a repair technician. Regards, JUS004
Jan 12, 2008 | GE 32GT740 32" TV
Clicking off and on sound
The power supply is in the protect mode. There is probably a short in one of the areas on the circuit boards. It is also very likely that there is a scan failure. The set would have to be properly troubleshooted to determine that exact failure.
Jerry G.
Jan 06, 2008 | GE 32GT740 32" TV
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
GE 32GT740 32" TV Logo
241 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
