Question about Saws
MAKITA LS1211 MITER SAW HARD TO PUSH DOWN
THE SAW IS HARD TO PUSH DOWN OR UP. I TOOK BOLT OUT THAT SERVES AS A AXLE BUT STILL HAS THE SAME PROBLEM WHEN I PUT IT BACK IN.
  • 313 Answers
SOURCE: Craftman miter saw
should be located at the pivot arm assy where close to the motor.
Posted on Jun 03, 2008
  • 271 Answers
SOURCE: how do you ulock the saw to pull up the blade so you can put the wood underneath to cut
push down gently on the arm and reach around to the rear of saw with your right hand and pull retainer pin the arm should release and allow usuage of your saw.
Posted on Oct 24, 2008
picatudo
  • 239 Answers
SOURCE: changed delta saw blade
it turns the other way, to the right!
Posted on Feb 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do u unlock a 10'' benchtop compound miter saw
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
Jan 12, 2011 | Makita 10" Compound Miter Saw LS1040
How do i unlock a mikita miter saw ls1030n. i cannot lift the blade so i can use the saw.
should be a nob on back on motor side of saw that pulls out just a bit some times u hav to push down on saw to get it to pull out then let up on saw
Dec 14, 2010 | Makita 10" Miter Saw LS1030N
How to change a blade in miter saw
There is a button on the saw near the axis the blade spins on push the botton there should be an allen wrench that is supplyed with the saw that is mounted or stuck or attached to the saw this fits the bolt that secures the blade the bolt that holds the blade turns left handed so most bolts turn righty tighty lefty lossey this is oppisite turn it clockwise to lossen it
Dec 03, 2010 | Makita LS1013FL 10" Slide/Compound Miter...
How to lift blade on mikita 10 mitch saw
right side of saw is a spring loaded knob. push saw down and pull out knob - rotate knob 90 degrees.
Oct 14, 2009 | Makita 10" Compound Miter Saw LS1040
My two year old Makita LS1221 Miter saw will not allow me to change angle. locking pin does retract. table turns only with very,very large force and only a few degrees. I cannot seem to be able to lift off...
PUT THE CENTRE BOLT BACK IN PLACE SCREW IT RIGHT IN THEN UNDO IT 3 FULL TURNS THEN GIVE IT A GOOD CLOUT WITH A DRIFT AND HAMMER IT WILL COME WHEN IT DOES YOU WILL NEED TO GIVE IT AGOOD CLEAN UP AND REASEMBLE IT AND YOU SHOULD BE RIGHT
Sep 25, 2009 | Makita Tools 12" Compound Miter Saw -...
Sep 20, 2009 | Makita 10" Miter Saw LS1030N
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
How do you ulock the saw to pull up the blade so you can put the wood underneath to cut
Oct 08, 2008 | Makita 10" Miter Saw LS1030N
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
