Intrinsically safe AM/FM radio - Audio Players & Recorders
Cls 1413 motorola
anyone can hear anyone, but with the PL you wont hear them, unless they find it on purpose
Apr 23, 2014 | Radio Communications
Icom bp-127fm wont charge
Change the base unit or check the output of adaptor.
Oct 15, 2013 | Icom BP-227FM 1700 mAh Intrinsically Safe...
My golf mk4 am/fm/mini-disc player comes on but can't tune to any station. Only displays FM 76.0, do I need a radio code? I bought it as used from Japan 8 months ago. Please, I need your advice!
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a Volkswagen dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 2003 VW Golf radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Sep 06, 2011 | 2003 Volkswagen Golf
HELO MAY FREND. RADIO MOTOROLA GP338 IS INTRISCALYSEIFE
You can tell by looking at the radio. Either on the bottom or on the back of the chassis (where you would find the serial number) you will see a small green diamond with an FM logo inside. This would indicate the radio is intrinsically safe (factory mutual approved). If the radio is intrinsically safe you must also use an intrinsically safe battery. Check the battery for the green markings too.
Best regards.
Apr 15, 2011 | Motorola GP300 Compatible 2 Way Radio...
Audi radio in safe mode
Remove the radio from the dashboard
Then post the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on any LABELS, BARCODES or STAMPED IN THE METAL CASING
Jun 06, 2010 | 1998 Audi Cabriolet
How Do I Get My Radio Out OF Safe Mode? Anyone?
Hi.
The radio goes in safe mode when the battery gets disconnected, or if for some reason the radio lost power connection.
To get the radio out of safe mode you will need the anti theft code.
This is available with car documentation, in first page of the in car entertainment booklet, or on first page of the car booklet (not the car manual).
Once you have got the code, do the following:
  1. Hold down both the AM/FM and the SCAN button at the same time, until the display shows "1000".
  2. Use the buttons 1,2,3,4 to change each of the digits until you get displayed the same code as printed on documentation (ensure that it is the right one).
  3. On some radio (programmable models), the default code is "1111" or "1234".
  4. Press and hold the AM/FM and SCAN buttons again until the radio is starting.
  5. If you fail twice the code, the radio will lock up in safe mode, and you won't be able to enter the code again.
  6. If the radio is locked, or if the code is lost, the unlock can be done at the nearest car dealer, usually for a small fee, or for free.
Regards.
Feb 07, 2010 | 2001 Audi A6
My car got a buster jump yesterday and now my screen doesnt work
Make sure you have the radio code found inside your model information packet inside your glovebox…it will be on the radio and communications pamphlet. It is in safe-mode right now, so press and hold the FM button and the scan button until 1000, or whatever number is stored in your safe mode, appears. Enter your code by selecting the pre-set radio station buttons until the corresponding number appears; press and hold the FM button and scan button again and your radio should be reset.
Aug 22, 2009 | 2008 Audi A6
The radio says safe
To reset from SAFE leave SWITCHED ON...UNDISTURBED until it has automatically reset itself. This could take several hours.
For a code, quote the MAKE+MODEL of radio plus ALL the LETTERS+NUMBERS on any LABELS,BARCODES or STAMPED IN THE METAL CASING
Jun 27, 2009 | Grundig FR200 AM/FM/SW/DAB Radio
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
424 people viewed this question
 Grubhead
Grubhead
