Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
I have a Kodak easyshare 5300 printer and it will not print. Each time I send a print command the paper will feed through but the printing never actually begins. It will pull through two or three sheets of paper and never print. It then tells me that the tray is out of paper when it is not out of paper. Help please I want to do my taxes!!!
    Sergeant:
  • Kodak Expert
  • 285 Answers
Try pushing the copy and cancel buttons simultaneously if it doesn't work call 1.800.421.6699
Posted on Jan 28, 2009
KODAK 5300 PRINTER IS PRINTING PICTURES WITH A PURPLE TINT TO THEM
Kodak EasyShare 5000 series
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 10, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 will not print WordPerfect documents
try to print it via Microsoft word or adobe pagemaker
copy paste your word perfect files to word or adobe then try to print
remove all the printer softwares and pluging and reinstall them and try
try to go to my computer then select printer and scanner wizars from there and try.
Dec 16, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare 5300- Won't print
I fumbled around a similar problem today. After printing photos you have to convert the printer to print to paper. If there is a green LED on the printer your are in PHOTO mode. Reach into the 4x6 printer and pull back the slide and the LED will go out. Now you can print on paper.
Mar 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Yes, it is the printhead. They are defective. Kodak is aware ot this issue.
Dec 02, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 5300 printer 4x6 printer tray
it could be a problem with printer and least with the print head.......i would advice to contact Kodak tech support...........
Aug 25, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
78 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
