Question about Lexmark P6250 All-In-One InkJet Photo Printer
Printers OCR
I am having a problem installing my ocr for my printer can anyone help please
  • 2 more comments
  • juniavery Nov 11, 2007
    can i download off the internet ocr for my lexmark p6250
  • lynnsne Apr 04, 2008
    my scans dont come out like the original copy how do i fix this
  • krina May 24, 2008
    how to download ocr online?
  • jumalo May 25, 2008
    I have windows vista . What can I do install lexmark P6250
    Genius:
  • 2,985 Answers
OCR is a software that reads a scanned image then converts the images text to a text file. It is 2 separate operations 1. the scan which is like any image scan. 2. the read which does the business. Using this type of software can be difficult at times and is a steep learning curve. I would remove the software. Restart the computer Reinstall the software then learn how to use it with perseverance.
Posted on Jul 20, 2007
SOURCE:
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Error says that ocr is not installed
I hope this helps.
Feb 01, 2012 | Lexmark All-in-One Printer with PictBridge
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
I can't scan on my lexmark printer model x5650. When I scan a document it gives me the message " Install the OCR from the OCR folder". I can't find the OCR folder in my computer. What should I do".
The Lexmark OCR scan software is available in the installation disk that came with the printer. You can explore the installation disk and look for the Abby setup application in the OCR folder (for Windows). For Mac OS, right-click on the Install icon and choose Show Package Contents. Open Contents folder > open Package folder and manually install the Abby Finereader application.
However, if you don't have the installation disk, contact Lexmark technical support. Thanks.
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
I cannot get ocr with my F4180 Can you help please
You can download the trial version of the OCR from the following link :
http://finereader.abbyy.com/trial. This is the best OCR software available
Jul 15, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
X5495 - OCR Program Missing.
Do you have MS Office 2003 or 2007? If so, there is a Microsoft Document Imaging tool that you can use to scan text documents. You can also search www.download.com for free OCR tools you can use for the same purpose.
Apr 15, 2009 | Lexmark X5495 All-in-One &USB...
How can i use ocr on lexmard 5650
If it didn't come with any OCR software you can find some free OCR software by Googling free OCR. After you have the software installed, it's usually a case of browsing to the scanned image via the software and telling the application to convert the image into a Word document. Some applications have the ability convert to PDF as well. If you prefer a PDF document but your OCR application doesn't support that option, then download some free "print to PDF" software. Typically with this type of software you will not be able to edit a PDF like you will a Word document. Hope I was able to FixYa, please remember to rate my solution. Thanks.
Mar 23, 2009 | Lexmark X5650 All-in-One InkJet Printer
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
OCR with Brother MFC 5440CN
Abbyy finereader 6 works well with the 5440cn. The latest version is 9.
Apr 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
958 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
