I have a copy star cs-1815 error c6920 how do I reset it
2 Suggested Answers
  • 990 Answers
SOURCE: non english display cs 5035
Hello sir; Try to return to english first, the procedure as follow;
1, press the keys in order "10871087".
2, enter 018 press "start".
3, you can checksum for the ROM,reset main board, change language.
4, enter "001" press print.
Hopefully can resolve your problem, good luck!
Posted on Jan 07, 2009
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Caller service C6000 in kyocera km-2035
Error C6000 related to fuser unit, you can try to reset to see if it works, other wise you need to replace fuser unit.
try to reset following these steps:
press on the panel the key 1078 1078, this will take you to maintenance mode.
now hite the key 163 And then hit the Start key.
select Execute and press Start key again.
Turn the machine off and on.
Good luck
Copystar CS-1815 reports a paper jam at the document processor
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Apr 23, 2009 | Copystar CS-1815 Printer
I need help to install my copystar cs-1815
Its very easy let me know wat you want to do or if you want to send you the manual.
Apr 19, 2009 | Copystar CS-1815 Printer
Non english display cs 5035
Jan 07, 2009 | Office Equipment & Supplies
Error C6000
This is a fuser problem. Try this to reset:
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Jul 28, 2008 | Copystar CS-1815 Printer
Copystar CS-1815 waste toner
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Apr 17, 2008 | Copystar CS-1815 Printer
Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Nov 01, 2007 | Office Equipment & Supplies
112 people viewed this question
k24674
jasbo
jasbo
