Question about Acer Extensa 5420-5687 Notebook
Once I unplug the ethernet cable, I cannot go wireless.
I can get wireless on my other computers.
  • Scott Hill
    Scott Hill May 11, 2010
    you have to connect to a wireless network and it needs to be set p to let your computer on it the mac has to be added to the list to allow you on it, and if security is enabled you need to add that key to the connection as well
    hope this helps
"Ethernet cable unplugged"
A few things to try. Plug the cable into a different port on the router to rule out a bad port on router. Try a different ethernet cable (they do go bad). If this is an older router it may not be able to do logic swap on the pins and you would need to use a cross-over cable and not a straight through. Also check in device manager and make sure the computer is not allowed to disable the lan adapter in power saving mode. Also if your really want you can test your ethernet port by buying or making your own loopback plug. Look up ethernet stander T568A. You basically would buy a empty ethernet jack and run a short wire from pin 1 to pin 3 and a wire from pin 2 to pin 6. This will simulate sending data to another device (the other device will simply be the receiving pins on your own ethernet jack.
Feb 02, 2012 | Microsoft MN-820 802.11g/b (r88-00001)...
Hi guru, i wish you help me please!! i condigured my wireless router actiontec and i have internet acces in my pc by cable ethernet, but when i try on my laptop by wi-fi or with my celphone, it says that...
Ethernet gives network signals from computer server with connectivity capacities. Once the ethernet is connected to your computer, once of the computers within the network structure has a modem or signal converter box to capture and distibute signals. Your computer is functioning with ethernet cable connection as arranged default. Recent computers however have wiifii capacities meaning that, the modem box is not ncecssary to make signals recognised. Recent computers have builtin signal recepticles, once the programs wireless features are enbled, any available computer networks aer detected. Howver, the wiifii makes connectivity to networks by requesting password keys if the aletrnate computers have protected the entry. Simply said, your computer is ok to function with ethernet as regular achievement. only when the ethernet is malfunct usually caused by the computer that has the modem disconnecting from yours. Your computer should actually get better networking with only one of the method available either ethernet or wiifii. Attempting to receive signals with wiifii and ethernet at the same time impedes the network speed since the structures may only allow an amount of data passage for each network on the same computer. Use the computer wireless buttons located at the system settings area to disable the wiifii until a computer request within your knownlege request to activate wiiffii. Keep in mind that once your wiifii is enabled, another computer is sharing resoruces makign the computer slower if a password was not set.
Feb 04, 2011 | Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
Tryin to install router, but it says ethernet cable not connected? not good with computers,
You should have an ethernet cable between your modem and your router. If it's dsl or cable, either one will have an ethernet cable (looks like an oversized phone jack with more connectors).
BUT this is the important sequence to follow.
Assuming that your modem is working properly already, connect the ethernet cable between the router and the modem. then turn OFF both pieces of hardware AND any wireless computers. THEN turn on your Router first and let it boot all the way. Then once the router is booted, turn on the modem and let it cycle up.
Once this is done, you can turn on all the other computers etc on the system... that should get you up to working status!
Nov 16, 2009 | Linksys Wireless-G WRT54G Router
Want to hookup westell mod 327D modem/router to my desktop to use as a wireless router for my laptop . Also , what is the differance between the blue ethernet cable and the yellow ethernet cable besides...
The cables are the same, and the color is just to remind you which one goes to the DSL modem (or other Internet source) and which goes to your local network (LAN). Often the ports on the router are color coded the same way.
To make your connections, just connect the desktop to a LAN port on the router, and connect the laptop by wireless, there's nothing special there. The quick setup information for your router should describe just how to set it up, so be sure to read it.
Sep 27, 2009 | Westell Wirespeed VersaLink...
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
I am trying to hook up a belkin router to a desk top, gateway. with no success been on the phone with belkin for 4 hours, unsuccessful
i hope your not talking about the wireless router.....
unplug your computer from the modem, and link the modem's Ethernet port to your router's WAN port (this is important). Once you have that in place (and you may see a WAN status light come on), plug your computer into one of the other Ethernet ports using another Ethernet cable and see if you can get a connection........
Mar 12, 2008 | Computers & Internet
Cannot install my Belkin ADSL modem with wireless G router and wireless G USB network adapter
OK.
First plug your router directly into your computer via the ethernet cable that came with the router. You'll want to connect the cable to the port on the router that says "Internet" (it's ussally to the far left when looking at the back of the router) make sure the other end is plugged into your computer's Network Interface Card (NIC).
Plug your computer into the modem via the UBS connection.
Insert the setup cd that came with the router and follow the prompts.
Once configured then unplug the ethernet cable from your computer and plug it into the modem (which should have an ethernet (RJ-45) jack as well as a USB.
Now you can either hook up to the wireless connection using a wireless adapter OR you can plug your computer in with a ethernet cable to one of the outgoing ports on the back of the router.
Feb 23, 2008 | Computers & Internet
What should I do after "Easy Software Setup"?
just unplug the Ethernet cable from the computer and plug it into the router and put the other end of Ethernet cable in to the wan port of WA840G
Oct 25, 2007 | Arris WA840G 802.11g/b (49832000100)...
Acer Extensa 5420-5687 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
